10-12-2022
03:32 PM
03:40 PM
I have a Canon Image class D 570. When I use preview the scanner works fine. If I then select "scan" I get two vertical red lines on the scan, the left hand side is pink. I can avoid this if I use "save" after preview, but I don't like that.
Picture below.
Any help would be greatly appreciated
10-13-2022 05:55 PM
Hello,
It looks like the scanner needs service. It looks like the scanner bar under the glass is damaged or needs to be calibrated. In this situation, I would suggest contacting support at 1-800-652-2666 or logging into you MyCanon account to check your service options.
10-14-2022 08:01 AM
Thank you I will check. But it is only 6 months old and used in a private home, so needing service seems a bit much
10-28-2022 03:23 PM
Calling did not help. After about 25 minutes I was told it is all via the web.
Any idea how long the warranty is?
10-28-2022 03:35 PM
Your imageCLASS D570 is covered by a 1-year warranty. You can find the complete text of the warranty HERE and if your printer should end up needing to be serviced under that warranty, calling our support line is the fastest way to get everything set up.
Hope this helps!
10-28-2022 03:43 PM
Calling the canon support line or trying to get help from the canon website is a nightmare. Horrendous. Terrible. Pathetic.
11-08-2022 08:57 AM
Calling your support line gets me a computer.
Emailing your support gets me ignored.
Guess which company will probably never get my business again? At least we have switched to Nikon Cameras already!
03-23-2023 10:58 AM
Still no help from vcanon. I am going to the dump shortly and I can recycle it
03-23-2023 11:14 AM
Hector (the product expert - from support) recommended calling support to help get this resolved. His reply is ABOVE.
Support is at 800-OK-CANON (800-652-2666).
03-23-2023 12:15 PM
Tried what was suggested and it didn't work
Really is a piece of rubbish. And Cannon support is among the worst I have ever experienced! If you can call zero help as among the worst, not the worst.
