03-05-2022 12:03 PM
I inherited a Canon Color Image Class canon MF8280CW printer & have downloaded all the drivers from Canon - but I cannot find the printer when I go into the printer & scanner settings on the Mac. I have tried everything I can think of, upgrading the operating system on my mac, reloading the drivers, restarting the computer - not sure what else to do.
Thanks in advance for any thoughts.
03-05-2022 12:13 PM
Hi, New2Canon2022!
So that the Community can help you better, we need to know exactly which version of macOS you're running on your Mac along with how your printer communicates with your computer (i.e. Wi-Fi or USB). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
03-24-2022 01:41 AM
I have the same issue, I have downloaded the MF8280cw printer driver to my new iMac Monterey 12.3 but it cannot be found in the system preference
04-08-2022 02:04 PM
Hello Charlenechan,
If the printer does not appear in printers and scanners under system preferences, you can try reconnecting the printer to your network using the steps in the link HERE or you can make sure the USB cable is properly connected between the Mac and computer. Once the printer connection has checked/reconnected. Click on the apple in the upper left hand corner of the screen and then click on system preferences. Once in system preferences click on Printers and Scanners. Once in printers and scanners, you can click the + to pull up the add printer window to select and add the printer.
