Slow Printing from imageCLASS MF753Cdw
matthewmonfore
Super slow printing. like 1 pg every 2 mins for theSlow Printing Color ImageClasse mf753 Cdw.
Was working fine. This is ridiculous considering the year is 2023 and I paid hundreds of dollars $$$ for this.
I want to talk to a real person..
8 REPLIES 8
Moderator
Moderator
Thanks for joining the conversation, matthewmonfore!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or give our imageCLASS support team a call.  They're available Monday through Friday at 1-800-OK-CANON (1-800-652-2666).
Thanks and have a great day!
Does fine with black text printing, but I have the same problem with everything else.  Scanning 20 pages takes literally all day.  And printing graphics is extremely slow.  This product does not live up to its specifications and is not fit to be sold, especially for $$$.  It also randomly decides it will disconnect from the network so that you get an error when you try to scan.  It will randomly reconnect so you get to spend your day pressing the scan button more than once in hopes it is reconnected.
@eholpresti this thread has gone over 6 months without any replies.
Its likely your OS, and network environment are different from the user who started this thread.  To receive help, please start a new thread.  Please include the model of your Canon product MF753Cdw, the OS of the computer you are using it with (windows, MAC, version and build), how the device is connected and to what?  Wired, wireless, etc.  You mentioned receiving error messages, please include those as well.  Thanks in advance, we look forward to hearing from you.
ehlopresti
I'd like a solution from Cannon or call back by a real person, Cannon, instead of a lecture about how to post a better question.  There's no reason to start a new thread because I'm having the same problem as the title of this one "Slow Printing from imageCLASS MF753Cdw" in addition to non-functional scanning, which seems to be related.  I can live with the intermittent disconnections from the wifi if you fix these other two.
Hello!
So that the Community can help you better, we will need to know more information:
• Do you see any error messages?
• Which version of Windows or macOS are you using?
• How do you connect to your printer (USB or WiFi)?
Any other details you'd like to give will only help the Community better understand your issue.
If you're in the United States, and this is an urgent support need, please CALL 800-652-2666, 9:00 AM - 7:00 PM, Weekdays.
If you're outside the USA, please click HERE to find support options in your country.
Thanks, and have a great day!
ehlopresti
no error messages for the slow printing; the latest versions of macOS, and the slow printing/scanning happens with both wired and wifi connections to the printer;  how about some real tech support?
Re-read my post. Also read the Community Guidelines.
The slow scanning problem is with cannon image class mf753cdw.  I run an iMac with the M3 chip, 8gb memory, running Sonoma 14.6.1.  It doesn’t matter if I use a wireless or wired connection.  It also happens from other devices on the same WiFi network.
