Problem scanning from sheet feeder MF8330Cdn
Erikmes
When i try to scan multiple sheets to my computer from the sheet-feeder, this doesn't work.
Scanning from the sheet-feeder to a memory stick works fine, and also scanning a single sheet on the glass plate works good.
Is there anyone who recognizes this problem?
My PC has the windows 8.1 software.
Thanks a lot!
5 REPLIES 5
Patrice
Whiz
Hi Erikmes! I will be glad to assist you. I would like to ask a couple of questions so that I can get a better picture of the issue. 1. I understand that you are able to scan multiple pages to a USB device, but does the issue happen when making multiple copies at the machine? 2. Which program are you using to scan your documents? I look forward to your reply. Should you need immediate assistance, please contact us at 1-800-OK-CANON (800-652-2666).
Hi Patrice,
Thanks for your anwer.
Making a copy from the sheetfeeder works fine.
For scanning the documents, I use the canon MF toolbox 4.9.
Hope you can helpme!
regards,
Erik
Hello Patrice,
I still have this problem.
Can you give me assistance?
Hi Erikmes.
Thank you for your reply.
Does the "Input Method" show 1-sided or 2-sided?  Please view the image below:
I look forward to your reply.  Should you need immediate assistance with this issue, please contact us at 1-800-OK-CANON (1-800-652-2666).
Hi Patrice,
I don't have the "imput method" selection-option, because my scanner only allows one-sided scanning.
Avatar
