04-15-2018 11:41 PM
I am trying to make a copy of a 2 sided document.
I can't find anywhere in the settings where it lets me choose this option. The manual shows the settings should be there, but they are not.
What is going on?
03-01-2019 01:04 PM
Any update on this? I'm having this problem, also.
03-04-2019 11:26 AM
No update from me.. still an issue.
03-04-2019 01:16 PM - edited 03-04-2019 01:17 PM
After calling Canon, this model is unable to do duplex scanning. The imageclass 700 series can, tho.
02-08-2019 04:10 PM
Did you ever get this sorted?
I have same issue using the top auto loader. If you put your original on the glass it will prompt you to turn it over and rescan - then print. A rather useless way to make double sided copies IMHO.
01-27-2021 04:49 PM
Since the machine can't duplex scan, how do I copy a 2-sided document into 2 individual pages?
12-12-2018 08:02 PM
02-08-2019 04:46 PM
03-05-2019 06:10 PM
Hi tonysy.
It is possible that the other user has the MF634Cdw, which is why the 2-sided to 2-sided option was available. The MF632Cdw and MF731Cdw support manually copying 2-sided documents only from the platen. The document feeder does not support automatic duplex scanning. Please view more at the link below:
Manually Copying 2-sided Originals on the Platen
Regarding not being able to see the option for Copy in initialization menu, Copy is located under [Function Settings], so you will need to select this option if you do not see the 1-sided to 2-sided option.
