My mf733cdw laser printer
Jazziz
Good evening all! I have a MF733CDW Laserjet printer. When I print or make copies of letters, the black letters and images come out faded, all other colors(Y,M,C) come out great! Is this a setting issue? If so or if not, how do I fix this? I think Ive tried everything. I am using canon toners.
1 REPLY 1
Audrey
Enthusiast
Hi Jazziz,
Welcome to The Canon Forums!
Please print the Cartridge Log Report using the operational panel:
<Menu>  <Output Report>  <Print List>  <Cartridge Log Report>  Check that the size and type of paper displayed on the screen is loaded in the machine, and select <Start>
If the print out is light, and the cartridge level is not low. Remove the black toner carefully and rock up and down a couple of times. Please back in the printer and try the report again.
If still light, check to ensure Toner Save is is off:
<Menu>  <Function Settings>  <Printer>  <Printer Settings>  <Print Quality>  <Toner Save>  Select <Off>
You can save toner consumption. Select <On> when you want to check the layout or other appearance characteristics before proceeding to final printing of a large job.
You may need to replace the black toner cartridge, if the issue continues.
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
Friends and Family
