10-18-2021 04:55 PM - edited 10-18-2021 05:01 PM
I have set up an MF445 on a network. All printing functions work. The printer is accessible to two computers and 2 iPads. No network issues printing.
I am running Windows 10.
Scanning has been troublesome. I have turned off the firewall for the private network, implemented SMB, and implemented file sharing where I could.
Scanning to a shared file from the printer works sometimes. More often, a pdf file appears in the target shared folder with 0 bytes, the disappears when the printer signals that job is complete.
Scanning from the computer using the cannon scan software will command the document feeder to action, but then the scan progress bar remains at 0% before the process times out.
Scanning to a USB flash drive works fine.
I have updated the printer firmware.
To summarize, sometimes it works and sometimes it doesn't.
im guessing I have a setting that is hinky but I'm at a loss to figure out which one.
Thank you for any assistance you can provide.
10-20-2021 11:19 AM
I posted a question a few days ago that included multiple issues. In this post, I'm trying to understand a particular behavior that occurs when scanning from the printer to a shared file.
A PDF file appears in the shared folder at the beginning of the scan. Most of the time, the file has 0 bytes. When the transmission ends, the file disappears.
Does this indicate that the printer is communicating with the computer on which the shared file is located?
Does this indicated that the communication software on the printer is corrupted or is there something in the configuration of the target computer/share file that is causing the issue?
I'm have the option of returning the printer, but the shipping will be expensive.
Any thoughts?
11-24-2021 05:24 PM
