03-07-2020 09:59 AM
Hello,
Is it possible to scan double sided originals from the device control panel?
I cannot find any option to do so.
I can do it from the utility on the PC, but this is not convenient.
03-26-2024 04:34 PM
I had the same issue, and after working with a terrific Canon tech, we found the problem (at least in my case).
We tried removing all Canon drivers and devices and re-installing, but it didn't help. It turned out I had some sort of TWAIN conflict (it's a scanner standard for remote scanning). What DID help:
After that, I went into the MF_Scan utility and the checkbox was there. What I wanted was the Color and B/W options to be single-sided, and the Custom 1 and Custom 2 to be the same thing, but double-sided. It worked fine.
One other thing I liked: I turned off the date folder and aimed all scans to a single scan folder. I also changed everything to PDF to make it easier to file.
Hope this helps!
11-20-2025 03:34 PM
I tried all of the above and on mine scanning mode is only Auto Mode with no other options nor anything regarding double sided.
11-24-2025 03:51 PM
Hi blackJMYNTRN,
So that the community has all the information to help you, please confirm that the unit you have is the exact same Color imageCLASS MF743Cdw model as listed in the original post. If you have a different model please provide that model name.
11-24-2025 07:51 PM
I had asked these questions previously.
@blkJMYNTRN,
Please consider starting your own topic as I suggested previously.
Piggybacking on another users thread makes it more difficult for those of us trying to help.
Start a new topic here:
https://community.usa.canon.com/t5/forums/postpage/board-id/officeprinters
