Scanning 2 Sided on ImageCLASS MF743Cdw using MF Utility Scanner
lmremb
I'm needing to scan double-sided documents using the feeder on my ImageCLASS MF743Cdw.
I use the MF Utility Scanner but it does not give me the options for double sided.
Is there any other way to scan these?
It's several pages that need to be scanned front and back into one document.
4 REPLIES 4
Greetings ,
Single pass duplex scanning via the ADF can be performed from the MF scan utility or the printer's LCD.
What operating system (version and build) are you using your printer with?
blackJMYNTRN
on my end there is no such selection available.
blackJMYNTRN
For future, please consider starting your own thread.  This ensures your issue receives the visibility it deserves.  Its also not possible for you to mark an issue as resolved unless its your own.  Thank you in advance.
Do you have an MF743Cdw?
What OS version and build are you ising the printer with?
How is the printer connected and to what?
You appear to have the correct print driver installed.  What version of the MF Scan Utility did you install?  Did you get the utility from product's support portal?
Are you able to select single pass duplex copy from the printer's LCD?
