MF743CDW Button Panel Not Working
eneng
Just got a new MF743CDW and it seems that the buttons (Sleep, Home, Stop) on the operation panel are not working.
When it is on sleep and I press the Sleep button, it would wake up. But pressing the sleep button again does nothing.
Pressing the Home button doesn't return me to the home screen. For example, if I went inside Menu, pressing Home button is not doing anything. There's no way for me to go back to home except for restarting the or waiting it to sleep then waking it up to default to home screen.
Darius
Whiz
Hi eneng.
If the buttons are not responding correctly, you'll need to contact our phone-based support. In the case that service is required, they'll be able to help arrange for your options.  Our support is available at 1-800-OK-CANON (1-800-652-2666) Monday-Friday from 10:00 am to 6:30 pm ET, excluding holidays.
3 REPLIES 3
Darius
Whiz
Hi eneng.
eneng
I did call support and I ended up returning the printer.
nitaipadd
Any word on this issue?  Can you order a replacement keypad?  Is there some function that inadvertently disables these buttons at the bottom?
