05-28-2019
11:45 AM
03:31 PM
Hello,
Where specifically can I adjust the scan density in the MF733cdw? I scan from the printer to my PC. Currently, all scans are illegible. I also tried 3rd party scanning software and Scangear software, There is no place to adjust the density.
I have looked everywhere in the MF Scan Utility and the Printer web UI. The closest I can find in the web UI is "Function Settings-> Store/Access Files Settings-> "scan setting" however, once you click in, it is actually "Scan Settings USB Memory Settings" specifically for Scanning to USB Drive which does not help.
Settings/Registration: Function Settings: TX Settings > Scan and Send Settings >File Settings Density has no effect either.
Double sided and single sided scans are affected.
If you can help, please reply with specifics. I will never purchase another Canon Printer again.
11-17-2019 03:46 PM - last edited on 11-17-2019 03:55 PM by Porcha
I'm pleased to report that the latest version of VueScan (9.7.08), from (removed as per forum guidelines), works with the MF733CDw in all three scanning modes: flatbed, feeder, and duplex feeder. It works equally well when connected by WiFi or by USB.
11-20-2019 09:23 AM
Great!
Do you know if there is a way to get view scan and the ADF to work automatically with eachother? For example with anyother MFC in the world you can walk over to it. Feed the adf click scan, and the scan appears on your PC correctly either by file or open program. My problem with the 733 is all the scans are too light and are useless.
Do you know if there is a way to set up VuScan so it fixes my problem? Idealy, it woudl be nice not to have to deal with software at all and just have the scans correclty delivered to my PC.
11-20-2019 09:43 AM
VuScan is not Canon Software. If you need support for their software, you'll need to contact them.
Per the Canon Community Guidelines (that everyone agreed to prior to posting):
We may remove posts that could be considered:
If you're having issues using Canon Software, Support is happy to help. If you're in the USA, please call 1-800-OK-CANON (800-652-2666) weekdays from 8am to 8pm (ET) for immediate help, or visit canon.us/account to discover possible alternatite support entitlements.
If you're outside of the USA, you'll need to reach out to Canon in your country/region for support options. Click HERE to find contact information.
12-07-2020 09:49 PM
Sadly, this unadjustable too-light scanning seems to be endemic to the Canon SOHO multifuncltion line. You have an MF733cdw, I have an MF4750 and a friend has a yet another model. All have one thing in commmon: you have to jump through hoops to make a usable scan.
Not acceptable. I don't understand how they shipped even one of these.
03-02-2021 02:24 PM
I am having the same problem. I am scanning documents with pencil writing and non of the pencil is legible and much of it is invisible. This is about item number 100 of why I hate this machine.
04-04-2021 03:11 AM
Seriously Cannon, fix your unusable too light scanning to computer problem!!!
I am returning this piece of crap. How can you have a scanner that scans to computers that is completely too light and cannot be read? What a terrible implementation and terrible responses here from support.
02-15-2023 05:27 PM
Is there really no way to set a DEFAULT of darker scan? Going through the ScanGear menu for every single scan is not a good solution.
02-22-2023 03:20 PM
So has this issue never been resolved? I run a MF743 with the same issue. Can't make permanent enhancements to scanning from the printer itself. Scanning is illegible. Using ScanGear helps, but needs to be used every time. Overall scanning even with ScanGear is pretty bad. Not pleased. Canon, how about a driver or firmware update to resolve this issue?
02-22-2023 11:57 PM
I have the same issue on a MF733 and it makes scanning significantly slower and more cumbersome. Canon really should create a setting to adjust how light/dark a scan is that persists and becomes the new default.
05-01-2023 08:31 PM
I found this forum post in a web search because I was experiencing the same problem.
Compared to the blown-out scans I was getting, I was able to get much more satisfactory results from the scanner by changing these settings:
Scan Type: PHOTO (Even if it's text and photo, select photo ONLY)
Sharpness: -3
Density: 0
Data Size: Large
And always scan in color even if the page is black and white
I am scanning to a file server using the front panel of the printer. For my use case at least, it seems like any internal "processing" that the printer does really messes up the image. This combination of settings (always scanning in color, photo original type, -3 sharpness) seems to minimize or eliminate image processing done by/inside the scanner.
