06-05-2020 02:11 PM
Our office has a MF733Cdw printer, and about 3 months ago we started having ink smudging on the left hand side, about every 1.5" apart, on every printed and copied paper. It also happens with both black and colored printing. We have changed all cartridges between then and now, have run all cleaning and maintenance options, and the spots continue to get worse. (photo attached)
Any idea what is wrong with the printer? I am at a loss!
Thank you!
06-05-2020 05:52 PM
Hi moojuice.
If you haven't yet done so, try the following settings found in the printer's Special Processing menu:
Some of the other Special Processing settings may also help, if the above do not.
https://oip.manual.canon/USRMA-1738-zz-SS-enUS/contents/SS735_menu_0218.html#0910_h2_06
06-15-2020 10:28 AM
We have tried those as well, and no change.
06-15-2020 04:14 PM
Hi moojuice.
If the special processing options didn't correct the problem, you've done the cleanings, AND all of the toner has been replaced, then the printer may need service. Our phone-based support is available at 1-800-OK-CANON (1-800-652-2666) Monday-Friday from 10:00 am to 6:30 pm ET, excluding holidays.
