08-17-2024
05:52 PM
05:59 PM
Tiffany
My Canon MF733cdw prints out sheets with cyan speckles / spots distributed randomly throughout the printed pages, and the quality of the black is diminished. However, if the sheet has colors, the spots / speckles don't appear, and the black is good. It seems to me that this color laser printer has two different process; one if the page is only black and white, and the other for color. What is happening?
I've used the printer menu to access all the cleaning options, and I've wiped down the toner cartridge housings without effect. My work-around is to add color to every document, if I can. Is there a real fix?
#MF733cdw
10-22-2024 07:23 PM
I'm having the exact same issue with the same printer. Is there any resolution to ths?
10-23-2024 09:42 AM
I've observed that the spots / speckles are not present if you add color to the document. The color, position, or amount of the color doesn't seem to matter. It seems there's a different printing process when color is used that avoids the anomaly. Also, Amazon notified me that the black genuine Canon cartridge, was in fact a knock-off.
06-11-2025 10:25 AM
Hello,
If you are getting spots on your prints, it will usually point to toner powder in the paper path or a problem with one of the toner cartridges. If the spots are only cyan, you can check the cyan toner cartridge to see if it is leaking or you can try another cartridge to see if it resolves the issue. If you continue to have problems, I suggest contacting support over the phone at 1-800-652-2666. Our agents would be happy to assist.
