03-09-2020 11:17 AM - edited 03-09-2020 11:17 AM
I'm trying to scan the front and back of 1 page into a multi-page, single PDF file.
I know this printer does not have duplex scanning.
I'm ok with scanning one side on the flatbed, then flipping it over and scanning the second side, then saving it as one PDF file.
This is a trivial process on my Samsung multi-function and I'd have to think this is possible on my new Canon.
02-10-2023 09:42 PM
I figured it out! And literally made an account to reply and hopefully save the next person a headache!
If you download the Canon MF Scan Utility application on your computer, you can scan multiple pages and save as a single multipage pdf, BUT you have to initiate the scan from the Canon MF Scan Utility application on the computer, not on the actual printer/scanner device.
Place all the documents on the feeder and then, from the Canon MF Scan Utility application, click on "document". It will begin to scan, and then once it is done, it shows all the pages. Under each scanned page, it says the page number. (It looks like it's going to be multiple pdfs, but it isn't as long as the data format section underneath only says "pdf" and not "pdf -divide into single page files") If all the pages have appeared, click "ok." It will then make them into a single pdf file. Side note: I did enable "check scan results" before, but I don't know if that affected the outcome.
03-09-2020 11:31 AM
Hello!
So that the Community can help you better, we will need to know the Computer Operating System you're using (Windows Vista/7/8/10 or macOS 10.x), as well as the way you connect to your device (USB or WiFi).
If you're in the United States, and this is an urgent support need, please click HERE to visit your My Canon Account to discover your personalized support options.
If you're outside of the USA, please click HERE to find support options in your country.
Thanks and have a great day!
03-09-2020 12:12 PM
I'm using the latest version of Windows 10
03-09-2020 06:29 PM
Hi sdyggm.
In order to scan a multipage document, the MF642Cdw's scanner driver (the recommended) and software (MF Scan Utility) will need to be installed on the computer. They're available, free of charge, at the following page:
Once they're installed, you may use the MF Scan Utility to set each scan option (for its own buttons and for those on the printer) as desired. The "PDF" option will scan all sheets scanned in a single session to a single PDF file, while the "PDF (Divide into Single-Page Files)" works as named.
03-09-2020 07:00 PM
03-11-2020 02:09 PM
Hi sdyggm.
Try enabling the Check Scan Results setting for the relevant scan type. Keep in mind, changing the scan option for one scan type will not have any affect whatsoever on the other scan types (i.e. changing this setting for "Document Scan" will have no affect on the scan options on the "Color" or "B&W" Scan from Unit options, and vice versa). Each scan type you wish to affect will need to be set individually, and the settings window re-entered after each such change.
03-11-2021 05:43 AM - edited 03-11-2021 05:46 AM
Thank you @sdyggm for being very clear about your question. We are in the same predicament and, like you, have no issues manually flipping over a few pages on occasion.
We just got our Canon today and dumbfounded this trivial (and common) use case, that can be solved in software, is not provided to all those with simplex ADFs units [across their entire product line]
Places we looked:
It was suggested to use an online utility to manually merge 2 separate PDFs (frontside scans and backside scans) and this would be a complete hassle for a 3 or 4 page double-sided document.
It hasn't been 24 hrs and I can't believe I'm ready to return this unit back to the store.
I absolutley hate creating e-waste and did a TON of research to help avoid a situation like this. I even skimmed the entire 773 page user manual before purchasing and while I still give credit to Canon for writing a great manual, I was left feeling like manual duplex scans were not going to be an issue and that we could save $130 over the MF644Cdw.
Foiled again and hope someone at Canon is listening and implements the necessary changes to the firmware and their software to ask for more pages to scan!
05-10-2021 12:39 PM
I too cannot believe duplex scanning is not available. My previous scanner of 10 years had this and I assumed all modern scanners had this functionality. I have had the 642 for over a month so returning to get one with this functionality is not possible. An upgrade to the software to enable this would be great - but for now I will just have to keep using the 10 year old Xerox scanner and delegate the new Canon to print only functionality. Very dissapointing...
05-19-2021 01:06 AM
02-10-2023 09:42 PM
