10-29-2015 02:06 PM
I have a new MF6160W copier and it worked great for two days.
Now when it is initially started in the morning, it will make a copy from feeding it from the top. Then after that it won't feed another document to be copied. It says an original is in the feeder. I have to turn it off and back on in order to feed something to copy. Is there somewhere I can change a setting so it will always feed when I want to?
Thank you
11-02-2015 05:33 AM
11-03-2015 02:06 PM
No Luck. I check around everything and all tape has been removed.
Thank you
