05-16-2019 11:55 AM
Can someone help me with how to get the RX fax that is waiting to print? There are 4 that are sitting there and I can not figure out how to print them. Thank you!!
05-16-2019 12:54 PM
Hi Lainie.
If the Use Memory Lock function is set to On, please follow the steps below to disable the setting:
<Menu>
<Function Settings>
<Receive/Forward>
<Common Settings>
<Set Fax/I-Fax Inbox>
<Fax Memory Lock Settings>
Select <Off> in <Use Memory Lock>
<Apply>
The documents should begin to print. If you still continue to experience an issue, please call us at 1-866-261-9362 or 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
05-16-2019 12:54 PM
Hi Lainie.
<Menu>
<Function Settings>
<Receive/Forward>
<Common Settings>
<Apply>
05-16-2019 06:02 PM
