10-04-2015 04:47 PM
after switching to Windows 10, I have lots of problems in scanning documents. Essentially, the computer says that it cannot communicate with the scanner. There was certain tweaks that will eventually allow it to scan (unplugging and replugging the printer and restarting the computer, attempting a scan in control panel/devices and printers via the scan method there), but as soon as I've left the computer sit for a few hours, I've lost the scanning function. There are no new software drivers to address this problem - the Canon website immediately detects I"m using Windows 10 - but it has no drivers suitable for Windows 10.
Please, can you help!
10-05-2015 03:25 PM
Call the Canon support line. I have always found them very helpful.
10-05-2015 11:51 AM
Have you installed the two recommended downloads from 7/15 and 8/15?
10-05-2015 03:23 PM
yes. Many times.
10-05-2015 03:25 PM
11-12-2015 03:45 PM
I believe that the fix for this will be a new driver that has not been released yet. Does anyone know otherwise?
12-10-2015 05:04 PM
that is absolutely true. Canon needs to release a new driver to accommodate Windows 10. The support technicians were extremely helpful. But they are not magicians. The Imageclass D1150 (and undoubtedly many other printers) simply are not compatible with Windows 10.
12-31-2015 03:50 PM
Today I encountered a problem that the scaner work around could not resolve. The work around was to remove the D1150 in control panel, reboot the computer, pull the USB connection, reconnect, back to control panel to set the newly created D1150 as the default printer. Canon Tech Support determined that the Windows Image Acquisition (WIA) service was not functioning. They suggested calling Microsoft Tech Support, 877-696-7786, which gets the group that deals with Windows 10 Updates.
They created a case number and the technician who responded was very aware that it was a Microsoft Windows 10 problem. The only near term solution is to revert back to the previous OS. They expect to take a long period of time for an update to fix this to be released. So if I want to use my scan function I need to revert back to 8.1. Others who used 8 or 7 would need to go back to that level.
06-07-2016 07:20 PM
Load drivers and Toolbox, conect printer to usb2, Go to win Accessoriesin in Aps, Click on Win Fax Scan, Follow directions.
Worked for me
07-20-2016 01:01 AM
I tried this and it worked but was not the Toolbox - scanned another way - via Windows 10. It scanned images as pictures and didn't give me option to scan as one pdf document.
I'm still not able to figure out how to get Canon Toolbox to work in Windows 10. Any more updates on this. It stopped when the Windows 10 was installed - typical Microsoft aggravation!
07-20-2016 01:04 AM
Did you ever get this? I waited until the last minute to do the Windows 10 move and when I did it now the Toolbox to scan into pdf documents doesn't work or doesn't work consistantly. It works once and then you have to go through all sort of things of removing things from Task Manager and rebooting system, unpluggin pringer USB cable....none of this a fix and none of it convenient.
Curious if anyone else have had this issue and if they figured out a fix.
