03-30-2023 01:23 PM - last edited on 03-30-2023 01:32 PM by Danny
I purchased an ImageCLASS MF743Cdw printer in January. This printer will occasionally print a blank page with a faint chevron on it after a print job completes. It doesn't print right after (e.g. it isn't a separator page). I'm not sure how long after as after the print finishes, I'll leave the room and when I return sometime later, there is the page in the output tray. The chevron is very light as if it were a water mark. How do I turn this off? I've looked at all of the settings I can find and don't see anything that looks like it would control this.
Thanks,
04-11-2023 04:17 PM
Hello Hsutherland,
The chevron pattern that prints is a part of the automatic fixing assembly cleaning. You can adjust the fixing assembly cleaning setting using the steps in the link HERE. You can turn the setting on/off or you can change how often the fixing assembly cleaning is performed.
04-11-2023 04:17 PM
Hello Hsutherland,
04-13-2023 10:06 AM
Thank you. That makes sense. I've noticed that the rate of this happening has decreased. So, it seems like a start up process when the printer is new. At least more frequent then
