03-14-2017 07:31 PM
I don't remember what I set my manager ID and PIN to on my printer; how do I reset them (or factory reset the whole printer if that's what's required)?
It is an imageCLASS MF6160dw
Thanks
03-15-2017 04:20 AM
Hi rkon,
The factory default System Manager ID and password is 7654321 for both ID and password. If this was changed, We will be happy to provide you with the steps to reset the printer. Please contact our Desktop Printing and Imaging Solutions Department at 1-800-OK-CANON (652-2666), 8A-8P EST, Monday - Friday (excluding holidays). The support representative can perform a printer reset after you provide proof of purchase. I apologize for any inconvenience this may cause; however, these steps need to be provided by phone with a technician assisting you through it.
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
03-15-2017 04:20 AM
Hi rkon,
02-26-2019 09:52 AM
I have the same question for Canon imageCLASS LBP612CDW Color Laser Printer. Will this process work on my printer?
Thanks
Mel
03-05-2019 05:13 PM
Hi msinkler.
Yes, you will need to contact our telephone support group and they will be able to assist you with resetting the information. Please call 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
06-12-2023 09:52 PM
I have imageclass mf641cw. I dont know if it will help yours, but worth a shot. i press/release volume button. then tap/press the Red or Stop or Exit button 5 times. then press volume button again. it should bring up a screen that ask for ID. put in 43810. hit apply. then hit Yes to install and its reset.
12-19-2023 03:45 PM
Thank you! Works for MF656CDW.
01-29-2025 05:31 AM - edited 01-29-2025 05:32 AM
Thanks, Tommy! It worked for my Canon ImageClassD1650 perfectly! I didn't find anything online, it only asked to call an 800 #. We're all not in the same time zone, and we are not gonna wait hours for canon to open, however kudos to you Tommy for sharing!
01-29-2025 05:35 AM
This worked for me, ImageClass1650
03-17-2025 11:20 AM
Thanks tommyznguyen! This worked for my imageclass mf465dw. It took a few tries to bring up the ID screen because the front panel buttons are a little finicky to register touch/presses.
As a reminder to others who find this: After the reset, you'll have to go into the printer settings again to manually setup the system manager ID and PIN before you can login remotely on a computer.
05-29-2025 10:24 PM
Thanks totommyznguyen! This just worked for my MF741C. Worked first time.
After reset I can remote login System Manager Mode with no creds.
