01-15-2014 11:02 PM
I saw some replies for another MF series printer, but the instructions did not make sense to me. I have gone through EVERY possible option in the print dialog boxes. I think this is something set on the printer itself somehow.
THe weird thing is that on my old computer with the same printer, I had an option in the Print dialog box for "Finishing." That allowed me to specify (and obviously I could save that setting in a preset). But, with my new computer and new download of the drivers, etc., "Finishing" is not on the drop down menu. I do see Basic (which someone mentioned in a post), but that doesn't deal with 2 sided printing.
Please help!!
Thanks,
Cameron
03-19-2020 11:55 PM
04-07-2020 03:39 PM
Thanks gcervo for this. However, this does not work my my MF733CDW printer. There is no such option listed. I can get to the administration menus, however nothing works.
Canon, you should be ashamed of your products with this. I can't believe the poor quality of your products and support. I have been on hold waiting for well over an hour this time - and this is the third attempt. I've never ever been able to contact anyone. This is not documented anywhere, and yet it's a known issue. It's unfortunate that Canon is tarnishing the name and reputation with shoddy development and non-existent support such as this. I suppose Canon finally got removed from my "approved vendors" list. You know it's bad when Dell support is better than you, and you've hit that mark squarely Canon.
01-23-2021 05:55 PM
Hi there, I keep trying to change defaults using this CUPS thing, and it asks for a login. I've used my computer login, my printer login, and even called my work's support line to get them to try the administrator login for my system. I've tried 3 different browsers. None of them work!!!! ACK......so....... close......... But, still can't change my defaults. I'm on a Mac on Big Sur operating system v 11.1. Any advice?
08-06-2021 03:14 PM - edited 08-06-2021 03:52 PM
Doesn't work with MacOS 11 and MF445dw: General has only a Page Size drop down -- no Print Style menu.
EDIT: Print Style is in the FInishing section (not General). Setting it to 1-sided Printing, and then clicking Set Default Options underneath and entering my MacOS login, changed the setting there, but (after a power cycle) didn't change the behavior of the printer. I still can't get 1-sided printing.
11-15-2021 03:45 PM
I have an iMac and just upgraded to Calalina v 10.15.7. Previously my OLD Imageclass D480 worked fine, but after the upgrade it only printed double sided. I knew it was the driver, as I can copy single sided just fine. I realize this post is about a different printer, but the instructions worked!! i had to poke around a little bit as the layout of the utility is a little different, but I found it and am delighted that my 13 year old printer is alive and well. gcervo, thank you very much for sharing this info, I have spent hours on this before I saw your post.
10-16-2016 01:50 PM
Try this: WIndows 10 OS
It worked for me; hope it works with yours.
Cheers!
06-07-2017 11:38 AM
Artnkman, thank you! Have been dealing with this issue for a year + on Win 10
01-05-2017 05:53 PM
Thanks. this helped me also.............eugene
01-20-2018 03:29 AM
I am not sure if it is because i am running macOS 10.13.2 or if it is because the drivers arent correct but when i attempt to click on the settings in the layout I cant adjust them... Another thing that i noticed is there isnt a way to add more layouts if i so chose. Unclear if the issue is the mac side or if it is maybe a printer side. But i also notice my printer is MF216n model so unclear if my model has double sided printing.
01-20-2018 03:30 AM
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
