02-12-2019 08:11 PM
My machine is ImageClass MF236n
I do not want to receive faxes on it - I use eFax to receive faxes on my email. But I do want to send faxes.
The telephone line I connect to the printer to send faxes is the same line that I use for regular telephone calls. What RX settings are appropriate to ensure that the machine does not respond to incoming calls ?
02-13-2019 02:26 PM
Hi zayde!
It is recommended that you set the receive mode to Manual. Please follow the steps below to change the receive mode to Manual:
1. Press
and tap <Fax>.
2. Tap <RX Mode>.
3. Select [Manual].
I hope this information is helpful to you. If you require any further assistance, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
02-13-2019 02:26 PM
Hi zayde!
1. Press
and tap <Fax>.
2. Tap <RX Mode>.
3. Select [Manual].
02-20-2019 10:06 PM
