09-24-2020 10:40 AM
What does this message mean and why don't the functions work?
Could not perform correction
I get this message after running either of these functions:
Correct Print Color Mismatch
Auto Adjust Gradation
What is preventing these functions from working? (Does it simply mean there is nothing to correct?)
How can I fix the problem?
09-26-2020 08:44 PM
Here are the steps from the documentation to perform a Full Adjust:
<Adjust Image Quality>
<Auto Adjust Gradation>.10-07-2020 12:54 PM
Welcome to The Canon Forums!
Please remove and reset toner cartridges. If the message continues, please replace with Canon Genuine Toner Cartridges.
If you continue to have difficulties, please contact our support group using the following link:
11-20-2020 04:34 PM - edited 11-20-2020 04:34 PM
I have the same issue and the phone support is impossible to reach.
Is there anything I can try to resolve this?
11-20-2020 04:45 PM
I got it.
You need to make suyre that your paper settings match the ones displaied duren the gradation adjustment screen prompt.
Select plain 1 in the paper settings basically
04-20-2022 09:28 PM
This information is invalid on two counts: first, you do not explain what you mean by "reset" for the cartridges and that is also not explained in the downloadable owners manual; and second, the link you gave for further help led to a general Canon sales page. I would have expected more from a designated "product expert".
04-20-2022 09:32 PM
I know in my case this was the default setting and had never been changed. I suspect that was true for charliemullen as well. So this is irrelevant and does not respond to the problem.
06-09-2022 02:09 PM
Agreed, the guidance is worthless. Canon, you can and should do MUCH better than this.
11-09-2022 11:46 AM
I have the same problem. Canon has replaced this printer 6 times and all eventually have this issue. I usually get one to two months of use out of a printer before it starts printing faded and am unable to run the Correct color Mismatch or Auto Adjust Gradation.
I've always run genuine Canon toner cartridges. I now have a large collection of toner cartridges that are included in about every third new printer I receive from Canon.
Latest drivers are installed. Printer firmware is up to date. We have been on the phone with tech support that we know by heart every troubleshooting step they ask us to go through.
I've always been a big fan of Canon printers and have had many over the years but this model leaves a lot to be desired. I'm sure that Canon is aware of the problems as I've seen numerous posts around the internet about this issue, I wish they would fix it.
11-26-2022 06:10 PM
This helped me run the adjustments. I went into the paper settings and unchecked all but the plain 1 paper and letter sizes. It's BS to have to do this, but it worked.
