Clogged printhead on Maxify MB5120 that does not respond to deep cleaning
Yankee
The black ink on my Maxify MB5120 is not printing well on documents and is almost unreadable. There is no "low ink" indication that the cartridge is low or out of ink.  I therefore tried cleaning the print heads multiple times to no avail.  So I followed the process for deep cleaning the print heads via the control panel on the front of the printer.  The problem still exists. I then followed the instructions on the Canon support page to power down, wait 24 hours, and perform deep cleaning again, yet the problem persists.
Any thoughts on my next steps to correct the problem? (Note: The printer is out of warranty.)
Thank you!
5 REPLIES 5
Hector
Hello,
If the black is not printing properly, it could be caused by the ink tank or by the nozzles in the print head. With the Maxify series, the ink will not move to the changing position until the printer detect that the tank is empty. You can try continuing the cleaning until the level is low enough to replace the tank.
If you are using a third party tank, it could be what is causing the issue, some third party tanks can cause ink flow issues. If the ink is not flowing properly, it can cause ink level detection issues or streaking in the prints. You can check with the ink provider if that's the case to see if they have any options to remove the tank.
If those steps did not resolve the issue, it looks like the printer needs service. Outside of the 1 year warranty, you can contact our sales department at 1-800-385-2155 to use our Upgrade Program. The Upgrade program will give you a discount and free shipping on a replacement printer.
Thank you.  I removed the print head and cleaned it under water.  It cleared up the original problem, so the black is printing well now.
However, the yellow is not printing at all now, despite having a brand new ink cartridge in place.  (I am using only Canon cartridges.) The yellow ink level on the display shows it is full, but no yellow ink comes out. So, color printing is not coming out as desired.
Does this mean the print head is irreparably damaged?
Hector
Hello Yankee,
If you have manually removed the print head and cleaned it and now yellow is not working, it will usually mean the print head is damaged or the ink flow for yellow is blocked. You can try reseating the ink and print head one more time and try 2-3 deep cleanings to see if it starts to print again. If it does not, it would mean the print head is damaged.
I'm sorry - this is not a solution and really not good product design. I have an XL ink tank. I've done 2 cleanings and 2 deep cleanings and the black ink level hasn't moved nor have all these cleanings fixed the problem. I'll did was try to print a tax return in black and white. There is no way I am going to take this printer for maintenance and I need to print documents today. It should not be this hard to replace an ink cartridge. Unfortunately this means I am going to find a new printer and it can't be a Canon.
I found the manual way to change the ink cartridge and that resolved the problem when both cleaning and deep cleaning did not work. It was just a Canon ink cartridge that went bad and that needed to be swapped. It would be amazing if Canon would consider this kind of problem in product design and troubleshooting.
