09-10-2013 06:45 PM
I have an ImageClass mf4370dn and it suddenly has a black vertical line that is printing when I scan a document. It does not show up when I copy it. How do I repair the equipment? Thanks!
07-31-2019 11:53 AM
Bingo! Abosolutly right. Glass LOOKED clean but it wasn't. As I slowly passed my finger on the glass I could feel something. I took a credit card edge and removed what ever it was. Wiped with a clean soft cloth and problem solved. No more lines. To be clear, this was on the small strip of glass in front of the big glass bed. Thank you.
03-08-2019 09:06 AM - edited 03-08-2019 09:09 AM
Voila! Thank you Mr.19th!! That finally did it! Thanks so much!
07-10-2020 10:17 PM
03-08-2017 09:17 PM
I just started to have this issue. I have run the "fix/clean" twice and no black ink on the paper. I cleaned the rollers but still the black solid lines....... HELP. Thank you
03-08-2017 09:36 PM - edited 03-08-2017 09:37 PM
Hi, 1985slh!
To have a better understanding of your issue, please let everyone know the model of the printer you have.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help via Email at http://Canon.us/SupportCF
You can also use the following link to browse our library of user manuals by clicking HERE.
Thanks!
03-10-2017 10:29 AM
I can't see your scanner, but scanners have to be perfectly clean or else you will see some line if there's anything resting on the glass where the scanner moves.
08-21-2017 02:06 PM
I have an Canon Imagerunner 3035. It suddenly has been showing thick vertical lines. It also notce that it has a greater tendency to do paper jams and seem to be running hot.
I disconneted the machine however, I am concerned that reconnecting is not going to be enough. What do you recommend?
Neil Binder
03-20-2018 07:26 AM
New to this so not sure if I'm posting correctly.
I have an Pixma MX926 when I scan a document via the ADF a black vertical line has suddenly appeared… I have done all the usual clean, deep clean and platen glass clean.
In other posts...Not sure how the credit card is being used or where
Would appreciate any advice on what else to do…Thanks
03-20-2018 10:58 AM
DBRS
I have an MX922 so I hope it is similar to yours-
Photo 1 the tiny glass strip to the left of the platen glass- clean that and the black guide above it ( to the left of it).
Photo 2 the bottom inside of the lid, clean all of the black and white guides
Hope that helps!
03-21-2018 03:42 PM
04-02-2018 09:10 PM
