09-10-2013 06:45 PM
I have an ImageClass mf4370dn and it suddenly has a black vertical line that is printing when I scan a document. It does not show up when I copy it. How do I repair the equipment? Thanks!
02-02-2017 04:41 PM
I followed your instructions. Still getting line. There is a tiny little black spec on the top white portion that sits on the glass when closed. Could that be it. I tried glass cleaner. It would not come out.
02-02-2017 04:46 PM
That worked for me! Thanks.
03-08-2017 09:17 PM
I just started to have this issue. I have run the "fix/clean" twice and no black ink on the paper. I cleaned the rollers but still the black solid lines....... HELP. Thank you
03-08-2017 09:36 PM - edited 03-08-2017 09:37 PM
Hi, 1985slh!
To have a better understanding of your issue, please let everyone know the model of the printer you have.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help via Email at http://Canon.us/SupportCF
You can also use the following link to browse our library of user manuals by clicking HERE.
Thanks!
03-10-2017 10:29 AM
I can't see your scanner, but scanners have to be perfectly clean or else you will see some line if there's anything resting on the glass where the scanner moves.
08-07-2017 11:33 AM
Sometimes cleaner will not get everything. I had to use a plastice credit card and lightly scape the surface to get it completely clean
08-09-2017 06:50 PM
If the line is occuring when printing to the device, it is most likely the Drum or Imaging unit. You will need to buy a new one to remedy the line.
08-21-2017 02:06 PM
I have an Canon Imagerunner 3035. It suddenly has been showing thick vertical lines. It also notce that it has a greater tendency to do paper jams and seem to be running hot.
I disconneted the machine however, I am concerned that reconnecting is not going to be enough. What do you recommend?
Neil Binder
12-01-2017 03:26 PM
mr 19th !
Thank you so much! Due to your precise description, I was able to clean the smudge off the little glass on my MX 922 and eliminate my problem!
Maje
01-27-2018 05:56 PM
I have this same problem but only on the feeder loads, manual placement yields exact copies. Why?
