02-17-2025 04:49 AM
Hi there.
I have an issue with our Canon MF463dw device (latest firmware) with one of my client.
Casually if they print with IP and with the latest Canon installed drivers (UFR II/UFRII LT Printer Driver & Utilities for Mac V10.19.20 [macOS 10.14.6 - macOS 15.2]), with the latest MacOS version (macos 15.3.1 Sequoia) everything is fine and working.
The scan via email function is working too and sending the file in the mail inbox. There is no error.
But when they want to print again after the scan the printer and the MacOS printer spooler also show a similar error:
On the printer: "Waiting (file name)..." and nothing happen.
MacOS printer spooler: "Waiting for printer to process the job" or something like that, and nothing happen.
After we restart the printer it is printing again, like nothing happened.
Cause | An error occurred because the main power was turned OFF due to an unspecified cause while a job was being processed. |
I am currently jumped in the Mac world a couple of months ago, I was handling Windows devices so might be some really obvious Mac-hack, but cannot find a solution for this one. Any ideas?
Technical data:
Basic Device Data:
Version Data:
E-mail/I-Fax Settings:
Authentication/Encryption Settings:
IP Address Settings:
DHCP Supplemental Settings:
DNS Settings:
mDNS Settings:
And from the MAC:
02-19-2025 10:30 AM
Welcome to The Canon Community, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Community is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please CLICK HERE and select your country or region for your support needs.
You're welcome to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
02-17-2025 06:55 AM
Update: scanning from the built in MacOS software also cause this error. So it is not because of the email scanning
02-17-2025 02:23 PM
I see you have a static IP address set on the printer. Did you reserve this IP address on your router? Or just took what the router assigned it and tried to make it static by disabling DHCP on the printer?
Please ensure you answer the question above accurately.
Is the printer installed on the Mac as an IP printer and using 192.168.48.2?
After scanning, are you able to ping the printer's IP address. Does it reply?
02-18-2025 02:13 AM
the DHCP pool starting from 192.168.48.100 - 199 and this static IP address is just for the machine.
I also tested this by turning it off and on the printer while pinging and of course there was no ping response until I turned it on.
Is the printer installed on the Mac as an IP printer and using 192.168.48.2? - Currently yes
After scanning, are you able to ping the printer's IP address. Does it reply? - Yes
02-19-2025 10:30 AM
04-02-2025 04:15 AM - edited 04-02-2025 04:21 AM
Hello, I have the same problem with the same machine - Canon MF463dw, the difference is that the computers in the network use WIndows 11 Pro, did you find how to resolve the problem?
04-02-2025 08:29 AM
I have the same problem with the same machine. Probably software related?
