11-18-2022 10:47 AM
I need to physically remove the wireless interface from the Canon PIXMA TR150 printer and use wired USB connection only. I know I can disable it in the user interface but that won't suffice. Has anyone ever tried to take one of these apart? Is there a service manual someone could send me on how to disassemble one of these units so that I may permanently disable wifi function? Thanks
11-18-2022 04:56 PM
1. Why do you want to "remove" the wireless interface? Why isn't disabling it enough?
2. The wireless interface is undoubtedly NOT a discrete component you can remove. It most likely is integral in the motherboard of the printer.
11-18-2022 05:34 PM
1. noyb
2. undoubtedly?, likely? sounds like you don't really know. did you ever take one of these apart to verify? if not please do not reply again
11-18-2022 05:43 PM - edited 11-18-2022 05:44 PM
How rude. Good luck.
11-18-2022 09:01 PM
Hi, Cyberdoog!
Welcome to the Community Forum!
Any questions Community members ask in reference to the original post are made to help the Community better understand your issue.
If unable or unwilling to give any rational explanation for your issue, please check out your other support options here: https://canon.us/MyCanonAccount .
Thanks!
11-18-2022 11:29 PM
He's going to need more than luck. The wireless interface cannot be physically removed without damaging the device.
The printer is not designed to be disassembled, changed or physically modified. Canon does not recommend or support this. It also voids the warranty. I have a feeling I know why this is being asked, but its not supported regardless.
11-21-2022 09:21 AM
I apologize. You are right, I was rude, and am very frustrated that we as consumers have allowed ourselves to become so vulnerable to cyberattacks with no apparent solution. Currently there are no wired (non-wireless) compact printers available on the market.
The answer to your first question follows....
We hijacked 28,000 unsecured printers to raise awareness of printer security issues (cybernews.com)
11-21-2022 09:35 AM
Perfect...
Looks like you don't have any registered products
You must have registered products in order to see support options
11-21-2022 09:45 AM
Hi. I'm not a tech; however, the article you've referenced specifies UNSECURED printers are at risk. Not to disable the WiFi. You want to change the default password. You'll find instructions for that HERE.
I hope this helps, but if you need additional help, let us know!
11-21-2022 10:00 AM
