05-31-2022 12:07 PM
Hello all,
I have a Pixma iP110 printer that will not turn on. The printer is only pulled out of a drawer for printing on occasion, so it's not plugged in all the time. We've printed 2 times since mid-April to provide an idea of the frequency the printer is used. New toner was installed mid-April.
Any feedback is appreciated. Thank you!
06-04-2022 12:02 PM
Hi!
We've released a firmware update to take care of this issue. Learn more now by clicking HERE.
Hope this helps!
05-31-2022 12:21 PM
Based on your description, you printer has experienced an internal hardware issue and would need to be replaced.
If you printer is outside of it's 1 year warranty, you would qualify for the Canon Upgrade program. This is for out of warranty units which have been diagnosed to require service or are incompatible with a new or upgraded system. This program allows you the opportunity to purchase a replacement product discounted from the list price. Free ground shipping is included with your purchase.
If you would like to take advantage of this offer, please the Canon Sales Department at (866) 443-8002 Mon-Sat, 9 AM to 9pm EST excluding holidays.
05-31-2022 01:44 PM
I had the same issue today! I started using the printer maybe 2-3 weeks ago to print something about every other day, and it was working just fine, until a little earlier today. The last time I used it was 2 days ago.
I have a battery pack attached to mine, but I have since removed it and only had it running via the power cord to isolate the problem, and it still powers off after those 15 or so seconds.
Does your printer also make a slightly different vibration sound (like a low hum) than it usually does during the startup process? It also doesn't seem to finish it's startup process, likely because it powers off before it can finish.
Separately, the room temperature and humidity where the printer was used/stored have been higher than usual since I last used the printer successfully (2 days ago), and I'm wondering if that made something go wonky.
06-01-2022 10:06 AM
It is incredible because canon don't solve this issue, the printer don't boot because the WIFI module. Remove the wifi of your home (the sid that the printer uses) and this will allow to boot the printer, after of that reset the printer and try again.. (I don't find any solution yet)..
06-01-2022 10:08 AM
No this not the hardware.. of the printer because all the users with the printer with 2,5 year have the shame issue...
06-01-2022 01:00 PM
I have the same issue. Printing daily until about 4 days ago when I ran out of ink. Got new ink --- and the printer won't turn on. Light flashes for about 15 seconds, ink cartridges move, then it just shuts down. I have unplugged and plugged, Wifi light is off; cannot check wifi because it doesn't turn on for long enough. This feels like an update issue.
06-01-2022 02:10 PM
I also connect to my printer via WiFi, and it was working fine too (I think my family has had the printer for 7 years). I don't know if Canon has an automatic driver/software update setup for its printers, but hopefully if that's the problem, they can fix it.
It's been 3 days since I was able to use it properly and yesterday was when I discovered the issue of the "only power light is on/blinks, ink cartridges move and printer makes sounds for a few seconds, but then stops" regardless of direct power or battery powered.
For reference, my ink cartridges had about 50% left in them the last time I checked (a few days ago) and I've tried removing and re-inserting them in case it helped (it didn't).
06-01-2022 03:45 PM
There is may users with the same issue, not even with IP110 even with other printers.. In order to recover the printer.. (poweroff you wifi) or change the SID and the password. the printer will start, and only use as USB, the other option full reset, enable the accespoint mode, change the wifi and put a static IP and an MAC but a fake DNS or no DNS, (I don't try this work arround).
06-01-2022 04:40 PM - edited 06-01-2022 04:41 PM
Ok I solve the ISSUE...
Is complicated, but you must avoid that the printer connect to internet.. you need to restart the configuration, config a new IP (no DHCP) and put a gateway that don't exist.. for example if you gateway is 192.168.1.1 you can put the gateway as 192.168.1.234 for example to avoid to the printer connect to internet.. and that is it... (you can try to said to the router firewall to avoid the conexion from the ip address form the printer.. (I don0t try this but must work aswell).
06-01-2022 06:30 PM - edited 06-01-2022 06:31 PM
Same issue on my iP110 too. Turns off after about 15 seconds. Just started yesterday. Looking around these forums, I see it is multiple printers from Canon that experienced the same issue, all on the same day 5/31/2022. Desktops and mobile printers. Canon has an issue on it's hands and is radio silent telling everyone they have a hardware issue on their printer and need to buy a new printer on their "Upgrade Plan". H-E double L NO! They better come up with a workaround for this soon!
