01-04-2016 12:57 AM
I am considering using an iPad Mini for mobile storage of RAW and jpeg photo files. I gather that the adapter that Apple makes for the iPad cannot be used to then transfer files to a standard USB memory stick. Does anyone have experince with using the Sandisk iXPAND stick for this?
Thanks!
01-04-2016 02:25 PM
http://www.cnet.com/products/sandisk-ixpand-flash-drive/
01-04-2016 07:55 PM
Thank you for that link. Do you know if a RAW photo file is seen differentially for storage than, say, a JPEG?
01-04-2016 08:03 PM
01-04-2016 08:21 PM
The iXpand manual has this entry. When I see this, I wonder if CR2 files will be supported. Someone must have experience with this.
Photos Supported file formats BMP, TIF, TIFF, JPG, PNG, GIF, XBM, ICO, TGA
01-05-2016 09:33 AM
You probably need to call them directly or get it on a 30 day exchange.
I know I can download Canon RAW to my iPad and see the image, but I know the iPad is using the embedded JPEG for the image.
01-05-2016 10:24 AM
@jrhoffman75 wrote:You probably need to call them directly or get it on a 30 day exchange.
If it didn't have any support at all for .CR2, would it even be able to find (or know to look for) the embedded JPEG?
01-11-2016 07:47 PM
After some research, I do believe that the Sandisk device can store a CR2 file because, as John Hoffman said earlier, it is still a file with 1s and 0s. And the iPad will store the CR2 file, but not display it. It will show the JPEG file that accompanies the RAW file, be it a thumbnail (if the camera is set up to shoot RAW only), or the accompanying JPEG if you have the camera set up to shoot RAW+JPEG. SOOO, I think a good process would be to shoot the RAW+JPEG, transfer to the iPad, then look at the JPEGs on it. The RAW files can be later put on your computer with the RAW converter.
Does anyone have this experience with backing up photos on the road? Thank you all for your inputs.
Edward
