How do you print a saved digital picture on computer to 4*6 photo paper on a lbp7660cdn laser prin
curious
How do you print a saved photo on a computer to 4*6 photo paper on a lbp7660cdn laser printer?
2 REPLIES 2
curious
How do you print a saved picture,  to 4*6 photo paper, on a LBP7660CDN laser printer?
Patrice
Whiz
Hi curious!
When printing custom paper from the imageCLASS LBP7660Cdn, you will need to register the paper size in the application you are printing from, as well as on the machine.  To register the paper size in the driver, please view the information below:
1. Select [Print] from the [File] menu in the application.
The [Print] dialog box is displayed.
2. Select this printer, and then click [Properties] or [Preferences].
3. Specify the settings for [Page Size] and [Output Size].
(1) Display the [Page Setup] sheet.
(2) Select the page size of the document created by an application.
(3) Select if the size of the paper to be printed is different from that of the data.
important:
If the [Page Size] setting and [Output Size] setting are different
  • The print is automatically reduced or enlarged to fit on the page.
4. Specify the other printing preferences as needed.
note:
For details on the settings
  • See Help. For details on displaying Help, see the "e-Manual" (HTML manual) in the CD-ROM supplied with the printer.
5. Confirm the settings, then click [OK].
The [Print] dialog box reappears.
6. Click [OK].
The printer starts printing.
To register the paper size on the printer, please follow the instructions below:
note:
Precautions when specifying [Mixed Sizes]
  • The printer performs printing without checking the paper settings in the printer driver.
Make sure that the paper specified in the printer driver matches that loaded in the paper drawer before using the printer.
  • If you are using the UFR II printer driver, load custom size paper whose long edges are 8.50 in. (215.9 mm) or less in landscape orientation.
1. Press [ ] (Feeder Selection).
2. Select the paper source whose size is to be registered using [ ] and [ ], and press [OK].
Select either [MP Tray Paper Size], [Drawer 1 Size] or [Drawer 2 Size].
3. Select a paper size using [ ] and [ ], and then press [OK].
Paper size is registered.
4. Select the paper source whose type is to be registered using [ ] and [ ], and press [OK].
Select either [MP Tray Paper Type], [Drawer 1 Type] or [Drawer 2 Type].
Whenever you change the printer driver settings, match them with the paper settings on the control panel.
5. Select the paper type with [ ] or [ ], and then press [OK].
I hope this information is helpful to you.  Should you need further assistance, please contact us at 1-800-OK-CANON (1-800-652-2666).
Avatar
