10-06-2023 01:13 PM
I use my Eos Rebel T7 on a custom camera stand to take photos of coins as part of my business. I connect via USB cable to my MacBook Pro and use Remote Shooting in EOS Utility 3.0 to focus, zoom and take photos. Then I stupidly upgraded from OS Ventura to OS 14 Sonoma, and now EOS Utility 3.0 doesn't work. I've checked the cable - it's working, as I see the camera in my Image Capture app. The EOS Utility just doesn't respond - sometimes I get nothing, and sometimes I get to the right screen where I would select Remote Shooting, but it's greyed out and I just have the spinning pinwheel. I have to force quit the app because it's not responding. So, clearly I upgraded to an OS that is too new and isn't compatible with EOS Utility. Is there any way to make my system work so I can still use live shooting? Will Canon be releasing an updated EOS Utility anytime soon?
10-06-2023 07:20 PM
There is a paid app called Kuuvik Capture from the App Store.
03-17-2024 06:57 PM
If you have a Rebel T3i or other Canon you may need to update the Firmware. I had firmware 1.0.1 and after upgrading to 1.0.3 I was able to remote control the camera using the EOS Utility 2.
I was able to download the firmware selecting OS X SnowLeopard v10.6
And downloaded EOS Rebel T3i / EOS 600D Firmware Update, Version 1.0.3 [Mac OS X]
The instructions are here
https://support.usa.canon.com/kb/index?page=content&id=ART114180
Maybe firmware update helps with other Canon bodies as well.
04-11-2024 01:22 PM
I have the same problem, shooting tethered with a 7D MKII.
I would switch the camera on, get the error message, switch it off, and repeat maybe 10- 15 times until it finally recognizes the camera. But some days, it just won't work. In this case, I'll try the old EOS Utility 2, which seems to be more compatible and works fine.
