10-23-2022
03:09 PM
09:42 AM
I HAD a problem when install mine EWC (Eos WebCam)
the problem starts from EOS Webcam do not pop up on my screen (basically a logo or something i remember)
but in background the service EWC.service was running
so i open my obs to test what happend, and as u can expect, just blank fill with the logo not connected sometimes.
i try reinstall as many time it doesnt work, change on service, and restart and reinstall many time doesnt work
the popup clearly not appear.
when i test on EOS utility it work basically, they detect and view my camera, but not the webcam.
i use the newest version from EOS webcam (updated sept 19 2022) , and mine WIN 10 x64, 60D
thanks before
03-05-2024 11:51 PM
Worked for me but only when I completely uninstalled EOSUtility. Neither works if both are installed on MacOS Sonoma.
06-13-2024 07:55 PM
In my case it does not work at all. Even having switched off the EOS Utility. I tried on OBS in two laptops and on Streamlabs. It still does not recognize the camera. Here you can see my settings for OBS. Maybe someone could help me, because I would like to use the Canon EOS 2000D for recording videos through Streamlabs or OBS and for streaming if possible.
06-18-2024 08:03 PM
Greetings Antonio2011,
Check to see if there are any other applications that may be attempting to communicate with the camera. This may prevent the EOS Webcam Utility from detecting the camera. When using the latest version of the EOS Webcam Utility, check to see if the utility itself is able to see a live image from the EOS 2000D.
On the camera, please check and ensure that Wi-Fi is disabled. Leaving it enabled, even when it is not currently in use, will disable the USB port on the camera. If possible, please test a different USB cable. Ensure that there is a memory card inside the camera, and that the camera is in the video shooting mode.
08-07-2024 05:01 PM
I have tried everything you've said above and I cannot get the T6i to work with my Macbook Pro. I either get a black screen or the red x with white usb icon.
Does the camera dial need to be in a specific setting? I have tried different cables and everything. I ensure they're data transferring cables.
08-07-2024 08:37 PM
Greetings zfly9,
You may set the Mode Dial to Scene Intelligent Auto (A+), but more importantly, set the power switch to the video shooting mode and not the photo taking mode. I would suggest on double-checking to ensure that the camera's Wi-Fi function is disabled prior to connecting the USB cable to the camera.
In case there is not memory card inside the camera, then let's test to see if inserting a memory card will help resolve this issue. You may also test to see if the camera can function as a webcam when it is connected to a different computer. This will help to determine if there is an issue with the computer you are trying to use the camera with.
08-08-2024 06:03 PM
This is so difficult. I've tried so many things. I don't have another computer to try on but I've done:
- 3 different cables, and made sure they're all data capable. USB-Mini to USB-C directly to macbook.
- different ports on the macbook
- wifi is off
- memory card in
- tried webcam utility regular and pro
08-12-2024 06:34 PM
Still cannot get it going, any other help?
08-20-2024 11:08 PM - edited 12-22-2024 09:38 PM
So I had a similar issue but with a Mac. What I did was go into the settings to tweak the configuration. Just to forced a system calibration.
I restarted my PC to avoid the two software running.
Then open the webcam app and then played with the setting.
From there reset the app and open it up and it should auto detect, if not go up into the windows option and redirect the camera setting.
Assuming that you already have the base camera software installed.
10-20-2024 02:21 PM
guys try to disable and enable camera driver FROM DEVICE MANAGER, it work for me to detected camera for couple times .
