02-05-2023 01:20 AM
Hello!
It works with webcam utilty 1.2 (if 1.0 is intalled before only), but if I install 2.0, no more display.
I tried with windows 10 and 11.
Operating System: Windows 11 Professionnel 64-bit (10.0, Build 22621) (22621.ni_release.220506-1250)
Language: French (Regional Setting: French)
System Manufacturer: Dell Inc.
System Model: OptiPlex 7010
BIOS: A26 (type: UEFI)
Processor: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz (8 CPUs), ~3.4GHz
Memory: 16384MB RAM
Available OS Memory: 16338MB RAM
Page File: 7921MB used, 18656MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, no HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.4.4
DxDiag Version: 10.00.22621.0001 64bit Unicode
02-05-2023 10:10 AM
Duplicate post:
https://community.usa.canon.com/t5/Camera-Software/EOS-webcam-utility-1-2-not-working/td-p/398057
02-05-2023 11:57 AM
It's not a duplication, it's only 2.0 the other post is 1.2 resolved.
02-07-2023 06:18 PM
Hello philogik,
There are a few applications that will not list or permit EOS Webcam Utility Pro 2.0 to fully function on your computer. In that case, you would need to use the regular EOS Webcam Utility not the Pro version. I have included a link, HERE, to our webpage for the EOS Webcam Utility Pro version which lists all compatible applications.
02-07-2023 06:41 PM
I don't understand your point. I indicated is a 80D and it's in your list. Did you check? So why it's not working?
