09-12-2015 10:40 PM
I get the error message "lost connection during import" when I try to import using EOS Utility and Image Capture. Is this a camera problem or could my usb cord be bad?
09-12-2015 10:51 PM
Hello WVgirl!
To have a better understanding of your issue, please let everyone know which camera you are using. That way, the community will be able to assist you with suggestions appropriate for your product.
Thanks!
09-12-2015 11:11 PM
I'm using the 60D.
09-13-2015 03:28 PM
Make sure your battery has an adequate charge (the USB cable does not provide power to the camera). If the cable is damaged then you could have a poor connection. But that could also be a damaged port on either the camera side or the computer side (but the cable is the more likely thing to wear out.)
