04-15-2022 10:57 AM
I recently purchased a additional lens for my Rebel T7, the EF 75-300mm. When I first got it, I was able to take a few photos. I then tested a wide angle converter with it and now it won't take photos without it at all using AF. It kind of works with MF turned on. But they still won't focus quite right. The camera works perfectly normal when I put my EF-S 18-55mm lens on. Any suggestions on how to solve the problem?
04-16-2022 08:07 AM
It sounds like at least two focal lengths are needed. One to get a wider shot to fit in more of the environment/subjects. The second, to get closeup details. If so, you'll find it difficult to have just a single lens for that, especially one that will help with the low-light.
I strongly recommend renting some lenses to see what may work best in your particular situation, then purchasing later.
Just a complete guess here, and quite expensive, but perhaps the EF 24mm f/1.4 would work well for your wide shots. Also thinking perhaps of the EF 135mm f/2.0 if you need a telephoto lens with more light-gathering capability than an f/2.8 lens. You can then trade some light-gathering performance with flexibility by looking at perhaps two zooms: EF 16-35mm f/2.8 and EF 70-200mm f/2.8 (or EF 24-70mm f/2.8)
04-15-2022 02:20 PM
1. Why would you want a wide-angle converter on a telephoto lens?
2. Was the converter something that screws on the front of the lens, or something that goes between the lens and the camera body? What is the exact thing?
04-15-2022 02:54 PM
Remove the “wide angle converter”, and never use it again.
Make sure that your 75-300mm is set to AF, and that you are not TOO close to the subject. Test the lens outdoors on a bright sunny day. Frequently, there is insufficient light for the camera to focus indoors.
04-15-2022 03:43 PM
1.) To see if it was going to help provide the wide shot I was trying to achieve for work. I'm very much an amateur.
2.) It screwed unto the front of the lens. It was a Vivitar wide angle
04-15-2022 03:48 PM
I did that and I still have the problem. It refuses to shoot in AF. I can only get it to shoot in MF and it looks like this when I try to take an outdoor shot:
04-15-2022 04:33 PM
Honestly, the 75-300 is Canon's worst lens. If it is defective it will be worth getting an alternative. What exactly are you trying to take photos of?
04-15-2022 04:55 PM
Sorry, but I have to ask. Is it a macro/wide angle device? If so, maybe you just removed the wide angle portion.
I just can't think of any reason why adding this device and removing it would mess up your lens unless it was hard to get on/off and you forced it and maybe effected the lens that way.
Newton
04-15-2022 05:43 PM
I work for a church that has large sanctuary as their communications director. One of my responsibilities is to take photos of worship services and other events at the church. Which the worship photos are the hardest part because I am supposed to take the photos without being in the front of the sanctuary or getting too far in the aisles (this is per the church board requests because of complaints about it being too distracting to the worship experience). I need to be able to stand a decent amount of distance away from the chancel and take photos that appear to be close up shots of like the pastor preaching or piano player singing. The reason for attempting the wide angle converter is because the chancel is oddly shaped and I have trouble finding the right place to stand to get the photos I need of a group.
04-15-2022 05:45 PM
I did remove the wide angle portion and that is what the photo above in another reply is. The wide angle converter came on and off easy. I didn't think using it would damage the lens either or I wouldn't have even attempted.
04-15-2022 05:49 PM - edited 04-15-2022 05:51 PM
Do you have another lens you can test the body with? Any EF-S or EF lens will do.
If the camera works with a known-good lens, you should get yourself a lens with wide-angle range. A good inexpensive option would be an EF-S 18-55 or an EF-S 18-135. They are readily available used (warranteed from a used equipment dealer) or possibly cheaper on eBay. Dealers I recommend are KEH.com, MPB.com, UsedPhotoPro.com.
A 75-300 lens on a crop-sensor camera is equivalent to a 120-480mm focal length on a full-size sensor camera. Definitely less-than-useful indoors.
