canon eos digital x shutter speed is not changing
pavindu
in my canon digital x camera when I scroll the dial in the manual mode instead of changing the shutter speed it changes apperture.even when i was holding the av button and scroll the dial same thing happens
10 REPLIES 10
deebatman316
Switch the camera to the camera to the Creative Zone ie (M, Av, Tv, P & A-DEP) then reset BOTH main and Custom Function back to factory default.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
pavindu
thanks for the reply but still didn`t fixed it  😞  do you know any other ways to fix it
Welcome. I am not sure what a “digital x” camera is, but does it have a menu selection to reset all camera setting and custom settings?
kvbarkley
If a reset does not fix it, then it sounds like the AV button is broken. It needs to be fixed.
yes
is there a way to know av button is broken or not
kvbarkley
If you press it in M mode and the shutter speed does not change, that is a good clue.
Moderator
Moderator
Thanks for joining the conversation, pavindu!
So that the Community can help you better, we need to know exactly which Canon camera model you're using. To date, Canon USA has released multiple EOS cameras whose model names contain the letter X but none where it's just the letter X.  That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
its called eos digital kiss x
