EOS R8 Error 70 in hybrid auto mode
Canon R8, 1.5.0 Anyone here experience having error70 when doing hybrid auto mode sometimes? All mode is fine except
I'm using an R7 with an EF 24-105 f4 L IS USM adapted to it with a Canon EF-EOS R adapter ring. I've been trying to micro adjust the lens but can not find a menu option to use. Is it possible that the camera/lens combination does not support it?
I have been a professional photographer for almost 40 years and relied solely on Canon products. Even endorsed them from the stage when speaking to forums. But today I will no longer ever purchase or endorse a Canon product. I have an EOS 5D Mark II ...
Suddenly my canon 70d camera stopped working and it doesnt start. Canon page says it doesnt support repair for this camera anymore. Can anyone help with solution? Thanks!
The past two days I've been using the Canon RF 100mm f/2.8 L Macro but I've seen it with other lenses such as the 100-500mm. I've also seen it mentioned in YouTube videos by the likes of Ian Wegener and Duade Paton. They are typically using the RF ...
Hello! I recently purchased the Canon EOS R50, and after accepting a request to update the firmware to version 1.4.0 (which i assume was to be performed over Wi-Fi), the camera indicated that there was an Update File Error at 81% completion and advis...
My Canon 90d won't connect to my phone anymore. It used to but it just stopped and started throwing err11
My EOS 4000D is new but while trying to import an MOV file to both IOS and Android, I get a message saying the file is not supported. Why is this? And how can I change it?
I just got my new mirrorless yesterday. First mirrorless camera and am excited to use it. However, when I took it out of the box I heard a little rattle-like noise. So gently shaking the camera body I can hear something that sounds like a plastic ...
Hello everyone, I just uploaded the new eosr-62v1.6.0 firmware on my R6 Mark II. I was a bit concerned with the idea of having to enter a password every time I turn on my camera or every time it powers off. However, after chatting with Rick (shadow...
Just bought camera and when off components rattle loudly at the easiest tilt. I’ve read it’s IBIS. It quiets down once turned on but still hear it.I’ve read the 6 has noise but doesn’t sound like a broken cheap toy like the mark2. May I get some feed...
EOS R7 with a RF100-500mm lens in FV mode I have been using this camera and lens for about 6 months and was getting along swimmingly with it. Today for some strange reason everything went wrong. It was a bright day and I was photographing insects. I...
Hi there,The help docs for the EOS R50 V suggest that you can set the streaming size when using USB (UVC/UAC) Streaming. However whenever I start the connection and plug in the USB-C cable to my Macbook Pro M series, I get a warning that streaming is...
I got a different lens for my camera and on some settings, (usually full auto mode) I get an "err 01" communications between the camera and lens is faulty, clean the lens contacts",but other shots / settings it works perfect. camera is Canon 1000d a...
| Subject | Author | Posted |
| 09-09-2026 07:04 PM | ||
| 09-09-2026 11:36 AM | ||
| 05-19-2026 01:06 PM | ||
| 05-14-2026 07:24 PM | ||
| 04-22-2026 11:08 AM |
