EOS DSLR & Mirrorless Cameras
Vertical line on all jpeg images
hi guys,From yestarday I have issue with my new Canon 5D Mark IV, on all jpeg images I see vertical line in the midle of frame. I don't see this line on RAW images. This line can be seen on camera display when I review captured image and the same lin...
olegolsh by Apprentice
  • 12333 Views
  • 18 replies
Problems with exposure
I have recently bought a new Canon 5D mark IV and am having problems with exposure.  I am using an older EF 24-105 lens. I have experimented with different metering modes and still seem to have the problem.  Two photos taken back-to-back with exactly...
shutter count problem
Why my Canon eos 200d doesn't add shutter count information to images? for this reason i can not check shutter count plz help..........., this camera new recently it purches.
Asim20 by Apprentice
  • 4014 Views
  • 2 replies
EOS R - Lens Microfocus?
Is lens microfocus available on the EOS R? It doesn't show by default in the menu. It seems odd to have this missing from a new camera, especially one this customizable.
mikul by Contributor
  • 7574 Views
  • 7 replies
Canon 5D Video
I know atbout the 4G file limit cut off for video, but is it possible to set the 5D II up such that it only send video through the DVI port but do not actually record on Flash. That way I can use the video previe for extended video recording. Thanks
Resolved! built in flash doesn´t pop up
Hello, I have an EOS Rebel XS camera. The built in flash isn´t opening and teh follow message appear:" Error 05     The built-in flash´s auto pop-up was obstructed. Turn de power switch to <OFF> and <ON> again."I´ve tryed several times with no result...
Resolved! Canon EOS 80D
I have just bought an 80D and find that when I use high speed shooting the buffer fills after 18 frames (RAW) and takes 15sec to get the preview screen back. This seems slow and I wwould appreciate any comments.thanks
rabby by Contributor
  • 7360 Views
  • 10 replies
EOS R Display - number in brackets
In the viewfinder just to the left of the battery indicator are two numbers on top of each other, e.g.   34[689] My assumption was that the top number is minutes of video available on the SD card and the bottom number is number of still photos availa...
  • 14609 Views
  • 4 replies
Resolved! Canon T5 Battery Door
Does anyone know how to put the battery door back on a Canon T5?  One of my photography students gave it to me with the door removed, so I have no idea how it came off in the first place.  I compared it to another one, and nothing appears to be broke...
filfoto by Apprentice
  • 6811 Views
  • 4 replies
REBEL SL2 FOCUS PROBLEMS
I recently purchased a used Rebel 200d.  I planned to use an EF-S 17-85 lens on it.  When I mount this lens, I cannot get a sharp focus.  Same thing with my EF 20-35 lens.  Has anyone else run into this problem, or am I doing something wrong, or does...
FTBNLOVER by Contributor
  • 13175 Views
  • 21 replies
