EOS DSLR & Mirrorless Cameras
Resolved! R6 mk2 V1.3 firmware not updating
I went through all the steps until the last screen where it ask if the firmware must be updated to V1.3. The OK button is grayed out and cannot be selected. My camera is currently on V1.1.4 firmware. Even when I tap on the cancel bitton there is no r...
Transferring pictures from EOS Rebel XTi to PC
I haven't used my Rebel XTi in a number of years and can't figure out how to transfer pictures from the camera to my PC. I have the cable but do not have original software disc and can't find it anywhere to download. The Rebel Xti isn't listed on the...
etojim by Apprentice
  • 4178 Views
Stack Focusing on R8?
Camera R8Is there any feature that allows me to do stack focusing and automatically processed?On my old 6D I did several shots and processed them using "Zerene" software. Thank you
R8 or R6? Partner has R5
My partner is much more into photography than I am and currently uses an R5. I'm considering buying a similar camera that doesn't have all the bells and whistles, but will be able to utilize the same lenses. I would be taking pictures primarily outdo...
yuresh by Apprentice
  • 9405 Views
  • 6 replies
Off camera flash Issue with EOS R
When I use the flash on the camera, the hot shoe works very well. However, when I use a trigger to take the camera off the flash, it does not work. I tested it with the same model of camera, and it works fine, but not with this camera.
fred007 by Apprentice
  • 1814 Views
  • 2 replies
T7i won't focus
My T7i has started to jump around when focusing.  At first it was quick to focus, but now when focusing it jumps back and forth and never focuses.  Is this a camera problem or lens problem?
daximus by Apprentice
  • 2340 Views
  • 6 replies
Why no Shutter angle on EOS R3?
I'm currently using an EOS R3 for commercial work/client work in marketing and advertising. it's the perfect camera for a 50/50 mix of stills and video work.I plan to get a "B Camera" at some point in the next year, but the lack of shutter angle pret...
EOSR3 by Contributor
  • 2227 Views
Canon R7 customization SET button
Hi All, I hope someone can answer this question for me.  I have recently upgraded from the 7D MKii to the R7.  I am very familiar with customizing buttons.  I am attempting to customize the SET button to magnify the image in playback mode.  I had thi...
Resolved! R3 won't power on
I'm having a recurring issue with my R3 simply not powering on. Never when I first insert a fresh battery, but after the camera sits idle for a bit. If I remove the battery and re-insert it the camera it usually powers on, but then I may have the sam...
jwn7882 by Contributor
  • 2390 Views
  • 2 replies
My EOS M50 Mark II Camera won’t turn on
I own a EOS M50 Mark II and everything was going great, i turned it on and i flipped the screen to take a picture of myself, i picked the black and white mode and all of sudden it turned off and it just wouldn’t turn back on, any tips?EOS M50 Mark II...
Bramzz2 by Apprentice
  • 5800 Views
  • 4 replies
