Why would my T4i Model number register as a T2i? Does Canon use standard bodies for all models?
When registering my new T4i. The Canon reply was thank you for registering your new T2i?
Hi, There are enough things to improve in Canon EOS 5D Mark III (5D3 for short), things which we hope (one can dream...) that will be improved in the next firmware update coming in April. (one can dream - again...) Well, it is known that nowadays the...
Hey Fellow 1DX folks,I've got another possible issue with my Canon 1DX- I've been noticing lately that when I'm shooting in Manual mode, landscape orientation, the exposure indicator on the right of viewfinder works as it should and photos set for co...
eos60 or rebelt4i? i`m a semi-pro Photographer , mostly need it for surf professional pics. what do you think?
When uploading pictures and videos, it says I/O problem, I am using canon rebel t1i...it was perfectly fine for three years and now it's giving me that problem.
Bought a refurbed EOS T2i and the flash is too strong and washes out photos. Can't override.Any options? I'm ready to return it.
T4i... lousy SD video... has anyone used SD and had final edit look ok. on timeline its a disaster. cell phone does better video.. im a pro video type and at this point may return cam and wait for a more capable eos.. like a mirrorless 60d...
If you are not using DPP wich of the following functions affect RAW images1.- Chromatic Aberration correction2.- Lens Distortion Correction3.- Noise Reduction4.- Long Exposure Noise Reduction5.- Peripheral Illumination Correction??Thanks in advance f...
Several times I have ended up with a dark spot on subjects eye, looks like subject ahs a "black eye". Once with 40D and on camera flash and others with 60D w/ 28-270mm lens and sunshade on lens and 580EX flash. What could possibly cause this.
Notice how the camera is off. Do not question me about the CF card because I am using Sandisk 32GB Extreme Pro 90/MB/s. Even after switching the camera on and off doesn't change anything, as well as switching different CF cards. Any 1DX users have th...
have a rebel 3ti and want to see pictures on computer as i take each one...can i do this and does it
Hello all, I need a replacement batteries for my Canon 1Ds MkIII; can I use the new LP-E4n? With the same charger? Thank you in advance.
My Rebel XS was working fine and then 5 minutes later I started getting a Busy error in the view finder. The screen is completely black. When plugged into my computer it does not show up. I have tried a new battery, different modes, and nothing helps...
When I record in canon (500d), I can hear the audio, but when you step to the computer only shows the picture, the sound is not recorded, but if you see the film in the canon, the sound is there. Can someone explain this?? thank you César
| Subject | Author | Posted |
| 05-19-2026 01:06 PM | ||
| 05-14-2026 07:24 PM | ||
| 04-24-2026 10:39 AM | ||
| 04-22-2026 11:08 AM | ||
| 12-18-2025 01:20 PM |
