Zooming
Can I manually zoom while the lens is autofocus or do I have to switch the lens to manual? I have a Canon T3i. Thanks
Hi, I'm fairly new to the 7D. I thought I had all my video settings correct, but when taking a video outside it is either too bright or washed out. I set all my settings in Manual mode then I saved it to a custom setting. Upon taking video, my Exposu...
I seem to have a lot of high video noise in underexposed aeras. This is specially visible in the blacks, it shows more because of the blacks and happens at all ISO values. On other forums I read this can be caused by camera been used a lot and or to ...
Hi guys. Title pretty much says it all. Picked my 60D up today and noticed that it will focus (I get the beep), but no focus confirmation (the red square) through the viewfinder. I have tripled checked all settings, cleared custom functions, made sur...
Canon any one tell me what is the picture style setting on the T3i. And how do you turn it off?
I am wanting to use a Sony Portable Audio Recorder PCM-M10 to send audio to the mike input of the Canon 60D SLR while doing video. I want to split the signal for use earphones to monitor the sound. Is there a recommented cable to do this patch fro...
What do I need to monitor audio with my Canon3ti I just purchased? I have Magic Lantern. Thank you!!
My camera is only a couple of months old. I have taken hundreds of pictures with it and I usually shoot on shutter priority setting. I took my camera to a wildlife park yesterday. It was clear, sunny, warm, no clouds. At least half of the picture...
I have new Canon 70d .. the problem when i start shooting video .. the LCD monitor shown in very high exposure ( white) .. the LCD monitor flashing with white distorsion !! anybody and gives me recommendation for the this problem
Recently when shooting in Manual mode, no matter how i change aperture and shutter speed, all photos turn out with a black screen. The images show black on back screen and also after imported onto the computer. any suggestions of what may be causing ...
I just brought home my brand new 5D Mk III, charged the battery up, mounted the lens (24-105), inserted the CF card and then the battery. Switched it on and no sign of life at all. Removed the battery, lens and CF card and then re-installed the bat...
Pardon my ignorance, but I can find no access to any sort of audio controls in the menu of my new D70.... Where are they? I should be able to manually set and/or see my audio recording level, shouldn't I?
Another question about 60d. Is it possible to shoot in manual camera mode with automatic iso? How can I set this?I usually use manual mode to shoot, but since I am about to shoot with low and changeable light, I wonder if automatic iso can be helpful...
I'm looking to buy an entry level DSLR camera, because I'm anticipating doing a lot of travel in the next few years. As far as Canons go, I think I've narrowed it down to the SL1 and the T3i. I'm looking for... 1. Easy to Use and user friendly- I've...
A problem about 60d: the quick control screen doesn't show up during shooting when I press the quick control button.I can see it during photography mode but not with the shooting mode.What could be the problem? Any suggestion or setting I can use to ...
| Subject | Author | Posted |
| 05-19-2026 01:06 PM | ||
| 05-14-2026 07:24 PM | ||
| 04-22-2026 11:08 AM | ||
| 12-18-2025 01:20 PM | ||
| 12-14-2025 10:25 PM |
