08-10-2016 06:46 PM
Hi!
I have a wonderful Canon EOS Rebel t2i that I just love to death. I bought it second hand and have been using it for the past 6 months. Today, I pulled it out to take a picture and the shutter stuck! This happens on M & Av modes, but not on any of the other & automatic modes. I checked the mirror lock and that's not on.
So basically, what happens is:
Camera focuses, I press to take the photo and the shutter makes it's regular sound and closes... and then does not open up again. There is a red light that blinks, the screen is black, and after about 22 seconds, it re-opens and the photo is over exposed.
What is happening? How do I fix it? How did this happen? I am currently traveling and won't be able to take it in for diagnostics immediately.
Thanks for the help!
08-10-2016 07:11 PM
08-10-2016 07:14 PM
Test it in M mode. In Av mode, the camera will select a shutter speed based upon the Aperture, ISO, and available light. A long shutter time could be normal for the conditions.
Try dialing in the same settings [Shuuter, Apeture, ISO] from the A mode, into manual, and take another test shot.
08-10-2016 06:51 PM
At least on M, what is the shutter speed set at?
08-10-2016 06:53 PM
It's at 1/250, F6.3
08-10-2016 06:55 PM - edited 08-10-2016 06:56 PM
Upload two pictures here. One from M or Av and one from Auto. Then we can take a look at the EXIF information bundled in the pictures.
08-10-2016 07:06 PM
@akouvi511 wrote:It's at 1/250, F6.3
Do you have a second lens that you try? We need to determine if it is the camera or the current lens. What lens are you using?
08-10-2016 07:06 PM
The top is in Av mode, the bottom is in full auto mode
08-10-2016 07:07 PM
08-10-2016 07:09 PM
08-10-2016 07:11 PM
08-10-2016 07:14 PM
