04-25-2020 01:51 AM
Hello,
I recently started filming with 3 Canon cameras: 70D, 80D and 90D.
I begun to wonder how is the best way to get the same white balance across all cameras.
I tested it and when I do custom white balance with a picture, the custom number value setting next to it does not change.
Is there a way I could get the number, somehow, what the camera set to while doing custom white balnce with a picture?
Then it would be easy to just set the others punching the numbers in.
Maybe someone more experienced can tell me what is the most practical and correct way to do this.
Thanks in advance,
F
04-25-2020 07:26 PM
FEJY,
You could shoot with the custom white balance and then check the EXIF data of the photos within DPP. This should give you the approximate kelvin value for the individual images.
04-28-2020 07:41 AM
Hello,
Sorry for the stupid question, but can I check it in the camera or should I take to a computer to check? Trying to make it a fastest workflow as possible.
04-28-2020 08:29 AM
You have to use a computer to see all the exif data
The fastest workflow would be to set one of the presets
04-28-2020 10:59 AM
"...3 Canon cameras: 70D, 80D and 90D."
I would set each camera to Auto WB. Take some shots with each using Raw format. Import into Lightromm or DPP4 which ever you have. Check the WB temperature, it should be close. This might give you a number you can punch in and be pretty close. It is easy to do WB correction in LR or DPP4 but you need to have a pretty similar gray sample.
Personally I would just forget it and do WB correction in LR as it is so simple. At least, that is, if I am understanding your question correctly.
04-28-2020 04:41 PM
He is shooting video.
04-28-2020 05:19 PM
@kvbarkley wrote:He is shooting video.
Ah! You're right. The word "filming" had sailed over my head (and probably Ernie's too).
But if one is that picky (and I don't at all blame the OP for being so), one should be using a video camera.
04-28-2020 05:40 PM
Setting WB for video works exactly the same way as it does for setting up stills. In fact, the best way to "calibrate" the cameras is to capture a still of a white/gray card.
This is one reason why I always tell people the secret to being a good videographer is to first become a good photographer. Everything works exactly the same way, except there a few additional constraints applied on how you capture images.
