10-17-2024 10:26 AM
My 06 year old Canon 200D SL2 still works exceptionally well in terms of number of shots with kit lens of Canon 55-250mm but when paired with a Sigma 150-600mm contemporary lens drains the battery very fast.
The lens motor seems to be running even when the power button is kept OFF unless I remove the battery from camera. The battery will drain off within 2-3h even without switching it ON when the lens is mounted.
Is it the small size of the battery or the incompatibility of the 200D with lens or may be something wrong with this particular piece of lens?
Any leads would be genuinely appreciated.
Thanks in anticipation everyone.
10-17-2024 10:28 AM
Do you have the lens image stabilizer turned on? It will greatly increase battery drain.
Rodger
10-17-2024 12:33 PM
Yes. Keeping it at OS2. Would it create so much trouble?
I tried to see the behaviour of this lens on a Sony Alpha6500 with a Sony to Canon adopter. The motor movement noise was not that prominent but still there was some sound from the lens. Couldn't check how much time would it take to drain the battery of the Sony Alpha6500.
10-17-2024 01:05 PM
The lens is connected directly to the battery, so if there could be a fault with the lens that constantly drains the battery. The only way to test this is to leave the lens off the camera until you actually need it, and put it on, take the shot and pull it off.
It could also be a weak battery. You might want to try a new one.
10-17-2024 07:29 PM
Image stabilization consumes a fair amount of power with this lens. I have one and have used it as a hiking lens on my 1DX III body and the battery drain isn't horrible but still noticeable even with the large battery pack used for the 1 series bodies.
It isn't just a Sigma lens "thing", IS use increases battery drain with Canon lenses also but some are worse than others depending upon the structure of the lens and how optical IS is implemented.
Rodger
10-17-2024 07:43 PM - edited 10-17-2024 07:46 PM
Hi and welcome!
The LP-E17 battery on the 200SL2 is neither large nor powerful, and the Sigma 150-600c is a big, heavy chunk of glass and metal, and so it has a powerful motor to focus with, and the optical stabilization is going to add drain too. The noise you may be hearing could be that. That drain can be further exacerbated by having Wi-Fi and Bluetooth turned on, which are also energy hogs.
You are not recommended to leave the battery in the camera for storage, I take mine out after each shoot and I use the big LP-E6 series in dual battery grips.
10-25-2024 03:33 PM
Yes. Agree about OS being ON and consuming battery when the camera is ON. But why when the camera is OFF and no shutter button is being pressed? It shouldn't then try to stabilise the lense, no?
10-25-2024 03:42 PM
Yes, the battery might have gotten weaker over its life of almost 06years now. But do you really think one can do this frequent connection/ disconnection of this heavy a lense? Practically a hastle it would be.
10-25-2024 03:45 PM
I agree with every word that you've said, Sir. I believe it is the combination of the heavyweight lense with an amateur body of SL2 that's to blame for this. Yes, I too take out the battery after every shoot but even during the shoot, when the lense is kept connected, it drains the battery within 2h of stand-by. That made me think about the combo.
10-25-2024 05:16 PM
With the camera off, it should not. Everything should be shut down at that point.
Rodger
