09-03-2022 08:48 PM
I currently have a Canon Rebel T3i with the included 2 lenses and 2 additional lenses i purchased. I use my camera for all things "kids" (indoor cheer competitions, outdoor cheer for school, indoor school dance team performances in gym, dance team performances on field, etc). My rebel has died and i'm looking for a new camera as the kids seasons has just started;) The last year i have started using manual and AV modes playing with manual adjustments.
I have looked at the Rebel 8i which had ok reviews but read everything is moving to mirrorless, so i looked at the Eos RP.
I would like suggestions for an amateur to take pictures for school events and sports indoors and outdoors. Sometimes lighting is poor so i need a camera that can adjust to lighting. This is not a camera for professional purposes but for family memories and scrapbooking.
09-04-2022 07:55 AM
A new Rebel may be better for OP without having to adapt lenses. Also the Rebel T8i allows AF at F/8 at the center AF point. If OP decides to use a teleconverter.
-Demetrius
40D, 5D IV, EF 16-35mm F/2.8L III, EF 24-70mm F/2.8L II, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
430EX III-RT, 600EX II-RT
09-04-2022 10:54 AM
I'm kinda leaning to the R10.....question will this be good for fast moving shots, some low lighting from football stands and gyms? Also the 18-150 lens would be great but will this work for close ups from bleachers to field? I usually use the EF-S 55-250mm lens. Would the RF24-240 lens work better (reviews didn't look great)?
Should i buy the R10 body only and RF24-240 lens OR R10 w 18-150mm lens kit plus adapter for either one I purchase to use my other lenses (50mm and 85mm).
09-04-2022 10:54 AM
" I use my camera for all things "kids" (indoor cheer competitions, outdoor cheer for school, indoor school dance team performances in gym, dance team performances on field, etc)."
You were, you seemed, satisfied with the T3i? Yes, no? Forget all the reviews. Most are worthless. If you were satisfied with the T3i you will love the T8i as it is a T3i only vastly improved. Just because they come out with mirrorless cameras does not make a DSLR useless or non-functioning anymore. They are as good as they ever were. And, in some cases even better than the mirrorless counterpart. Consider the T8i first off.
09-04-2022 03:27 PM
Your suggestion is absolutely valid about considering a DSLR alternative and I am glad to see a counter suggestion. I maintain that the OP should look at reputable reviews for any gear they consider - it's good practice and common sense. Sure, some reviewers are biased, but there are really good reviewers who are absolutely agnostic in their gear reviews and use standardized methodologies to give an informed presentation of a product's performance.
09-04-2022 03:38 PM - edited 09-04-2022 03:39 PM
Ernie, you said: 'You were, you seemed, satisfied with the T3i? Yes, no?'
According to the OP's original post "Sometimes lighting is poor so i need a camera that can adjust to lighting." Which suggests they were not.
My responses were based on this issue of seeking the best sensor performance and the FF sensor should provide a significant improvement in performance in this area - because of the new technology and the fact that it is a FF sensor and they are less prone to noise, given similar MP size.
Furthermore, the RP had eye tracking, the sensor displays what the image will be in terms of exposure - which an optical viewfinder does not do without using a stop-down button. The choice must absolutely rely with the purchaser, but I encourage it to be made by looking at several options and checking out the specs and reviews from reputable sources.
09-04-2022 03:48 PM
@Tronhard wrote:Ernie, you said: 'You were, you seemed, satisfied with the T3i? Yes, no?'
I’m not sure about that Trevor. As I read it she was stating that the replacement camera needs that capability. She didn’t state that she wanted to replace the T3i based on performance issues, just that it died.
09-04-2022 03:50 PM
I look at it as since the camera has died, then this is the time to look at getting that improvement. If they went to the trouble of mentioning it, it's a benefit they are seeking and that is a valid reason for looking at alternatives.
09-04-2022 05:25 PM
The adapter would work for continuing to use the EF-S 55-250mm lens with the EOS R10. I have used my ancient EF-S 55-250 on my EOS R5 and it works much better than it did on my Rebel T1i. I am not convinced that the RF24-240 would actually be enough better to be worth the extra money, but I have not tried it. With just the EOS R10 and the adapter you would be able to use all of the lenses you already have only with better auto focus and better low light performance than the same lenses on the Rebel T3i.
Purchased together, the RF-S18-45mm F4.5-6.3 IS STM lens adds only about $100 to the price of the EOS R10.
The others who have commented are correct that you could get much better lenses by paying more money.
09-04-2022 05:29 PM
Canon says of the EOS R10 "Subject tracking handed down from the R3 with people, animal, and vehicle detection" which seems to me valuable for photographing active people.
09-04-2022 05:44 PM
Exactly. There are new improvements in technology that will potentially significantly improve the needs of the OP in their pursuits of active people - kids or sportspersons. That is why I have suggested considering several of the R0-series: I looked at the RP for the benefits of its FF sensor within price, the R7 and R10 for their sports benefits. Of the latter two, the R10 seems like the most cost-effective.
