12-29-2021 11:35 AM
I've been using a DSLR as a webcam for a while now because I'm on calls frequently and want to have a higher quality video. However, I have to run it with a dummy battery plugged into an AC adapter in addition to having it plugged into my computer via USB-C.
I've been looking at the T3i as a lower-cost option for a webcam to replace the camera I'm currently using (which I'd like to start using for photography again rather than as a webcam). One thing I can't figure out is whether or not the T3i can be powered by USB/USB-C without a battery or dummy battery.
I've seen some articles like this one from B&H (https://www.bhphotovideo.com/explora/video/tips-and-solutions/how-to-use-your-canon-camera-as-a-webc...) that reference Canon cameras that use USB power. I haven't been able to find a video or walkthrough that specifically says whether or not you can use the T3i without a battery and just rely on USB power from your computer.
Can I use the T3i with just the USB connection? I'd love to reduce the amount of cords running around, so if I can't use the T3i without a dummy battery and AC adapter plugged in is there a model that DOES support USB power?
12-29-2021 05:55 PM
Your camera cannot be powered through its’ USB port. You would need to purchase an AC adapter and a DC adapter battery module to power the camera, or use the battery.
Your camera was released prior to using DSLRs as webcams became popular. I am uncertain just how compatible your camera is with the Canon EOS Webcam Utility.
https://www.usa.canon.com/internet/portal/us/home/support/self-help-center/eos-webcam-utility/
Not all features and resolutions are available on older models.
01-03-2022 09:49 AM
Thanks for the response! Are you aware of any (if any) models of DSLRs that can be powered solely by USB/USB-C? I've had a hard time tracking down that info.
