12-18-2022 08:36 PM
NMy R7 is stuck on manual focus. I have turned the camera off, removed battery, changed the settings. In the menu (AF - AF operation) only MF is an option. I've read of at least one other person with this issue who had to factory reset. Do I have any other options?
12-19-2022 11:50 AM
Oh, my - such a simple fix! Thanks so much.
08-06-2023 12:51 PM
My RF 35mm and my RF 24-105mm focuses well in my R7
10-17-2023 08:27 PM
Using a new Canon R7. Autofocus was working fine in the morning with a Canon 18-135mm IS USM lens and Neewar adapter. It had worked fine ever since I got the camera. This afternoon I took the lens and adapter off the camera body to check the fit of a new padded lens pouch. When I put the lens back on the body, adapter already attached, the lens was not fully seated into the adapter. I fixed that problem and I had autofocus again as before.
