10-15-2023
10:38 PM
09:05 AM
I know these two are the same camera, BUT I don't know if someone has noticed this yet. The 250D has weather sealing and the SL3 doesn't can someone explain it to me?
10-15-2023 11:18 PM
Where did you get the idea the 250D has weather sealing?
10-15-2023 11:25 PM
"The device is protected with extra seals to prevent failures caused by dust, raindrops, and water splashes". I got that infomation from this https://versus.com/en/canon-eos-250d#:~:text=The%20device%20is%20protected%20with,%2C%20raindrops%2C....
10-17-2023 08:41 PM
First, the Canon 250D, SL3, and Kiss X10 all refer to the same camera - the difference is simply a marketing one, so there is no physical difference.
I have checked three sources and there is no confirmation of weather sealing on any of them. I refer you to the specs from both Canon and DPReview.com: Canon EOS Rebel SL3 (EOS 250D / EOS Kiss X10) Specs: Digital Photography Review (dpreview.com).
I am not familiar with the site you quote from but under weather sealing it does display a x rather than a tick mark, and their comment about sealing is not very precise and IMHO, somewhat misleading.
10-18-2023 06:14 AM
The website you quoted clearly shows that the SL3 and 250D both do NOT have weather sealing. What you read there is a definition of weather sealing for cameras that DO have it so you can decide if that feature is important for your own needs.
10-18-2023 06:23 AM - edited 10-18-2023 06:24 AM
Baoluong,
I had posed the same as MikeSowsun, but didn't save the thread. According to the site you referenced, A red X means doesn't have a feature. Green check means it does. According to the site, the 250D is not weather sealed.
