12-18-2022 08:36 PM
NMy R7 is stuck on manual focus. I have turned the camera off, removed battery, changed the settings. In the menu (AF - AF operation) only MF is an option. I've read of at least one other person with this issue who had to factory reset. Do I have any other options?
12-18-2022 08:51 PM
Please share what lens you are using, and if you have tried with more than one? If the lens(es) is/are not Canon or are not RF mount, please tell us what mount adapter you are using?
12-18-2022 08:57 PM
Hello jlf100 welcome to the forums. Are you using native RF/ RF-S glass or adapted EF/ EF-S glass. I would check the AF/MF switch if this is an adapted EF/ EF-S lens and ensure that its set to AF. For an RF/ RF-S lens I would also check the AF/MF switch to ensure its set to AF. Some RF/ RF-S lenses do not have this switch. I would check the camera menu to ensure AF is enabled. Also ALL RF/ RF-S lenses are Focus By Wire including USM lenses NOT just STM lenses. Also does the electronic focus ring work too (assuming your using an RF/ RF-S lens) the camera metering system MUST be active for manual focus to work. This also applies to adapted EF/ EF-S STM lenses and adapted EF/ EF-S USM lenses which use an electronic focus ring.
-Demetrius
EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 28-135mm F/3.5-5.6 IS USM (Retired), EF 50 F/1.8 STM, EF 85mm F/1.8 USM & EF 70-200mm F/2.8L IS III USM
EOS 40D (Retired) & 5D Mark IV
430EX III-RT, 470EX-AI & 600EX II-RT
12-19-2022 07:38 AM
Hi - I am using the kit lens - 18-150. I have not tried another lens. Will do that now.
12-19-2022 07:41 AM
Just tried another lens (with an adapter) - auto focus works! Thank you! Any advice on how I get AF to work with the kit elns (no adapter)?
12-19-2022 07:43 AM
What EF lens did you try on the adapter. A Canon lens or a 3rd party lens.
-Demetrius
12-19-2022 07:46 AM
Using the kit lens. Just tried another Canon lens with adapter and AF works. Just have to figure out why the 18-150 will not allow AF. Relative novice here - maybe a trip to a local camera store is in order.
12-19-2022 07:50 AM
What specific Canon EF or EF-S lens did you try. The full name is on the front of the lens. It can be seen with the lens cap removed.
-Demetrius
12-19-2022 11:12 AM
RF-D18-150mm F3.5-6.3 IS STM
12-19-2022 11:45 AM
Yup, I ran into this issue last month. For me, it was changing the AF-MF switch to AF on the front of the camera. Too bad the setting doesn't show up on the menus.
