R6 Firmware 1.8.0 Causing Error 70
mushralph
Ok I recently update my R6 to version 1.8.0 firmware and I have noticed that when using the custom setting c1-3, there seems to be an error 70 generation. I have done a full settings wipe. Set up my settings from scratch. Then the problem resurfaces on while using the custom settings c1-3. Further deductions to the problem is this problem only arises on those settings on the dial and only after I attempt to take the shot. Furthermore I notice on my screen/view finder that with a 128gb sd card I go from approximately 4k raw files to roughly 450 files. I checked the file selection in main camera settings menu 1(camera icon). It only lets me select raw and can not change to any other settings for jpeg or craw. Once I move back to any other settings manual, FV, AV etc and turn the camera off and back on. The issue ceases. So I believe there is a bug in the firmware that's causing issues with the custom slots for the camera.
10 REPLIES 10
Updated R6 Firmware v1.8.1 Released - Canon Community
Which addresses Err70 specifically.
